Question Need Weber help
I just installed freshly rebuilt Webers. Engine won't start. I have spark all around. Funny thing is it will pop when I prime each stack with a small amount of gas but otherwise acts like no fuel. There is pressure from the pump going to the banjo. air and fuel screws are set at beginning set-up. The small accelerartor tube spits in dsamll quantities of gas when pumping the accelerator. How can I check to see if gas is otherwise actually getting in?
Old 11-10-2003, 08:47 PM
Bird. It's the word...
Fishcop's Avatar
Is you timing correct?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-10-2003, 09:18 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Are the floats filling up??
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 11-10-2003, 09:21 PM
Seldom Seen Member
Burnin' oil's Avatar
If your accelerator pumps are working but the motor doesn't run at all, even when pumping the throttle, then the problem is not with the carbs. The accelerator pumps inject fuel directly into the stacks, hence into the cylinders.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 11-11-2003, 08:33 AM
Seldom Seen Member
Remove the top section of the carbs to see if there is fuel in the float bowls.
Got nachos?
Old 11-11-2003, 08:48 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Use a float gauge to see what the levels are. too low and they won't draw fuel properly. Did you say a dismal amount of fuel fron the accel pumps? should get .5 - .7cc if I recall....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-11-2003, 03:16 PM
si2t3m's Avatar
Please describe how you are trying to start the car. Is it cold where the car is?
Here is what works for me when the engine is cold:
I turn the ignition key on and let the pump work for about 10 seconds.
I floor the gas pedal 2 or 3 times.
Then i engage the starter and it will usually start. If not, i'll floor the pedal 1 or 2 more times and start over. It usually start afterwards. When it's really cold, i have to play with the gas pedal for 10-20 sec once it's started, i'll let it warm up a bit at 1200-1500rpm ( < 1 minute). At some point the engine speed will increase by itself even if the pedal is steady. I usually take off after this.
HTH
Marc-Andre
Marc-André
Present: 07 997.1 GT3 white, 95 993 coupe Riviera Blue, 72 911E Targa Silver, 68 912 coupe Burgundy, 67 912/911 coupe Black
Past: 98 993 C2S, 98 993 Speedster conversion, 95 993 Cab, 70 914-6 conversion 3.0L Webered
Old 11-11-2003, 03:50 PM
Thanks much for all the good suggestions - now I have much to look for. Didn't have a clue before. I'll let you know how it turns out.
Old 11-11-2003, 05:56 PM
pjv911's Avatar
Send a message via AIM to pjv911
Though you were going to let us know how it turns out.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-22-2004, 08:13 PM
Garyo4's Avatar
I had a similar problem a couple of years ago when I installed new webbers on my Westy. I found out that one of the floats were stuck in the "up" (full bowl) position when unscrewing the top off the carb and heard a light "clunk" sound of the float falling down.
Tightened it up and it's been running great for over 2 years now.
Hope that's all it is.
Gary
'79 sc Targa
Old 02-23-2004, 04:03 AM
