Another clunking rear suspension (Not CV's)
I have a constant clunk in the rear of my 70 911"S" when I hit bumps or come off the curb of my driveway. The CV's have been replaced. Details are that the car has aftermarket sway bars and Koni red shocks. If the car is on flat ground, I can shake itfrom side to side and hear the clunk.....any ideas? WOuld a bad wheel bearing cause this? Bad shock? Thanks in advance.
Dave
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
I am told a deteriorated bushing at the bottom of Konis will do that.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
My Konis use Heim joints, but I havent had them off to check them
GFCC
Have you check your sway bar mounts?
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Dave, could it be bushings? My car has the old 1970's teflon bushings, and they are getting very noisy. Saving my pennies & dimes to have the suspension gone through, bushings all replaced (possibly neatrix?), and corner weighing.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Re: Another clunking rear suspension (Not CV's)
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I used to have a clunk in the rear of my '73. Replacing all the bushings (except the swaybar to body ones) got rid of the the clunking. My spring plate bushings were completely shot and replaced with a set of Neatrix bushings. One of my swaybar to body was a little loose so rather than pay $35 for that one bushing, I wrapped a little tape around the bushing to get rid of any play. I am not sure how long that will hold up as I haven't put many miles on my car.
Lastly, after you replace your bushings, you won't believe how much better you car will handle.
Neil '73 911S targa |
Senior Member
My car was making no noise when I bought it four years ago at 135k miles. Now, it clunks in the rear when going over bumps, and the clunking is (I'm pretty sure) the worn spring plate bushings. That's my guess on your car too. You might want to just jack it up, get under there and shake things. If you're wondering what suspension pieces should feel loose and which ones should not, ther's a simple answer to that. Nothing should be loose. Looseness causes clunking.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Re: Re: Another clunking rear suspension (Not CV's)
Besides, I have no friends
sway bar hitting the tranny case?
Could wheel bearings cause this?
Dave:
My '72 did the same thing. It turned out to be the outside cover plates on the rear spring plate bushings. They were worn and slightly flattened and the plate bunped against the top of the spline tube of the spring plate. You probably need to replace the rear bushings.
Marv Evans '69 911E |
I also have a clunk and after a bit of poking around I'm sure it's the rear wheel bearing. If it's been loaded up in one direction eg turning right, and I then make a sharp left (& vice versa) I get a clunk from the right rear wheel only. Another job for the winter...
3.2 Coupe |
Re: Re: Re: Another clunking rear suspension (Not CV's)
Dave, I'll be your friend! for the price of $10.00 an hour... and thats my bro deal. hahaaha! seriously though if you need any help.. call i'll PM the number to you since I am at Ashers and don't need her number scribed on mens bathroom stalls. Eric
When I see something horrible, I push the gas pedal down...... because I KNOW at that point eveyone else is lifting..... "Quote from GrandPrix" Last edited by Eric M@ Ashers; 11-15-2003 at 09:12 AM.. |
I second poking your head under there while someone else pushes it from the side.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Check all the bolts on the swing plates etc. I once had a guy leave off a bolt or left it loose after aligning.
I thought I was lossing my mind until I found it. Bob
Bob 1983 911SC Coupe Platinum Metallic 2020 Macan Dolomite Silver PCA Member |
Sounds like broken sway-bar mounts to me. If they have not been reinforced.... its not if they will break but when.
Terry
Terry |
