North Coast Cab's Avatar
Engine Drop - Whole Car Up
Is there any reason I can't raise the whole car up to drop the engine? I have some front end work to do as well so I'd like the car all the way up.
John
1985.5 944 GTS
Old 11-15-2003, 07:55 AM
Friend of Warren
If you are just using jack stands the biggest problem will be that you need to have the rear of the car about 36" off the ground. This is 24" at the torsion bar covers with the front tires on the ground. If you lift the front end up you will reduce the rear to front angle of height and thereby be forced to jack the rear of your car up even higher!
Kurt V
Old 11-15-2003, 09:26 AM
Bandwidth AbUser
Jim Richards's Avatar
We (the NoVA gang) typically jack the rear up part way to allow us to work underneath to disconnect everything. Then we support the engine with a motorcycle/ATV jack and the tranny with with a tranny jack. Next, we unbolt the motor/tranny mounts and lower them all the way. Finally we jack the rear of the car up until we can roll out the engine transaxle out from under the car. Like Kurt said, you won't have engough clearance with the front jacked up.
Jim R.
Old 11-15-2003, 03:11 PM
Now in 993 land ...
aigel's Avatar
Just get some ton jack stands and jack it up to the max. That will do the job, front and back. Buy a couple stands extra for your safety.
G
81 SC (sold)
Old 11-15-2003, 03:16 PM
Diss Member
Quicksilver's Avatar
Once you get the car in the air you are still missing a vital piece of shop equipment...
The official patent pending PorscheBoard!!!
After screwing around with the engine on the floorjack I came to my senses and cut the tail off of a $20 junky skateboard and screwed some blocks into it to hold the engine on the board.
It rolls extremely smoothly and you just tilt the engine to steer it. It took about 90 seconds to roll the engine/tranny out of the garage, into the driveway and get the motor correctly positioned to start jacking it back into the car. There was no cussing required!
Wayne
Old 11-15-2003, 04:07 PM
Monkey with a mouse
kstar's Avatar
Why not just keep the motor on the "PorscheBoard", fabricate some gears and belts to the "PB" rear wheels, a small gas tank/battery and a saddle over the engine for the driver?
BR,
Kurt
Kurt
http://starnes.com/
Old 11-15-2003, 04:29 PM
Irrationally exuberant
ChrisBennet's Avatar
On lowered Carrera's at least, if you don't have the front up a little (on planks or ramps) the spoiler will be pushed hard into the garage floor when you lift the rear.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-15-2003, 05:34 PM
MovOvr1's Avatar
I was wondering about the front chin spoiler as I have a 930 that is not that high off the ground to begin with. How high at the torsion bars do you need to get the car with the front off at the lowest settings for jackstands or on ramps underneath the fronts.?
Brian
Brian
BLK 79-930
Old 11-15-2003, 06:58 PM
Wayne
COOL! A 200HP skateboard!!
Chris
Old 11-15-2003, 07:21 PM
keithlambert7's Avatar
Priceless...
Keith
'64 356C Coupe
'89 911 Coupe
'99 996 Cab (sold)
'3 BMW X5 (wife's)
http://www.geocities.com/keithlambert7/
Old 11-15-2003, 08:56 PM
