lin7310948's Avatar
trailing arm upgrade number???
just installed 75 aluminum trailing arms into a 71 coupe. how do i upgrade the very small six bolt stub axle to the larger six bolt stub axle? is there a later year that will interchange ot will it require that i change bearings, hub assembly, as well as the stub axle. thanks for any help, larry
Old 11-18-2003, 11:55 AM
304065's Avatar
Larry:
Both should have four bolts, unless your arms are from late 75. Warren posted the changeover point.
Do a "search" under "aluminum trailing arms" and you will find dozens of threads describing the problem you are having.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-18-2003, 12:26 PM
