Start Problem
A new problem just came up, battery is good, turn key and get nothing from the starter. The fuel pump is running, but not even a click from the starter, any suggestions
I really appreciate some help
Old 11-18-2003, 06:41 PM
AFJuvat's Avatar
Please indicate year and model when you are asking a question, makes it a lot easier to troubleshoot.
When you say you get "nothing" - you mean no sound at all, or just a click?
No click: ignition switch fault and\or wiring fault at the ignition switch or starter. Possible dead starter
Click and no start: Starter fault or wiring fault.
Yes, you can remove the starter from MOST 911 with the engine and transmission in the car. you need to get teh car up in the air and use a 10mm hex on the one nut you can get to, and a short 3\8 socket wrench with a LONG 10mm hex socket (preferably a ball tip)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-18-2003, 08:57 PM
Cool
I would jump the starter solenoid with a screw driver to give more info.
and I'm with AFJ on your 911 info.. Put it in a signature......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-18-2003, 10:35 PM
