SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Joe, I'm sure Bill is right, now I just want to find out why I have mine set up the way I do. It's time to hit the books.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 11-26-2003, 08:33 PM
Bill Verburg's Avatar
The lower one has the check valve to retain vacuum for the brakes.
The check valve is that last piece that goes into the mount.
Itried to upload this pic before don't know wh7y it wouldn't go.
Bill Verburg
Old 11-26-2003, 08:36 PM
Pete000's Avatar
Just a quick question. Will that engine pass emission test here in CA? If so how with that exhaust system? I just purchased a 3.6 C2 and really like the B&B headers. How much do they ad to the power?
Nice work!
Work to Live, don't live to work...
Old 11-26-2003, 08:41 PM
Pete, Jack Olsen posted dyno results w/ B&B exhaust and a No Bad Days chip here.Dyno Results
The exhaust will not pass smog in CA, unless they don’t know what they are looking at or don’t care. I will need to install a Carrera exhaust to pass the smog visual.
Bill, I'm 99% possitive that the way I have it set up is the same as Ingo and Paul. It's worked fine for them but now it bothering me that I don't know everything about why it's the way it is.
I've got two days to figure it out or else we'll just have to see.
'81 911SC Targa 3.6
Old 11-26-2003, 08:50 PM
RETIRED
Joe Bob's Avatar
OK....how do ya hook up the SC cruise control so that is works with a 3.6?????
2012 ML350 3.0 Turbo Diesel
Old 11-26-2003, 09:07 PM
That should be easy. But I wouldn't say I'm on a roll here.
The biggest problem is the throttle linkage. It would have to be fab’d and is something I might start working on in a couple months. As far the SC CC itself, the only thing it needs to make it work is vacuum (T’d off of the brake booster line) and a way to hook the cable up to the throttle itself. It’s really completely independent of the engine other than that.
I would like to get mine hooked up too Mike. My foot likes the floor too much not to.
'81 911SC Targa 3.6
Old 11-26-2003, 09:14 PM
RETIRED
Joe Bob's Avatar
Lemme know....I miss it.
Old 11-26-2003, 09:19 PM
Senior Member
Mike,
Give me a break! You know only two throttle settings everytime I have ridden with you, either full on and idle. Cruise is something that you have forgotten many years ago!
Joe
Old 11-26-2003, 09:20 PM
Origuinally I wanted the cruise to work also. Never got it to work though.
Right now I would be ecstatic to get the diagostic port setup. Moses has one so I know it can be done and is likely easy but darned if I can see how to do it.
Bill Verburg
Old 11-27-2003, 04:44 AM
Senior Member
Bill,
Ingo sure knows the innards of this conversion and the DME and its electronics. Wonder if we could not bribe him to look into getting everything working. A case of good German beer perhaps???
Joe
Old 11-27-2003, 07:04 AM
I'm in
Bill Verburg
Old 11-27-2003, 07:10 AM
yellow911turbo's Avatar
Send a message via AIM to yellow911turbo
Franziskaner no doubt. I just got back to the states. Has anyone seen that in stores here???
Old 11-27-2003, 07:16 AM
One of our local taverns has it on draft, don't know if its the real deal all the way from the Fatherland though.
Bill Verburg
Old 11-27-2003, 07:20 AM
