Angry Might as well flush $7 down the commode
Stuff like this just irritates me to no end......
Part number 24A on the diagram has to be in the top 5 of the most retarded parts on my car. It's a rubber cylinder that mounts to the engine lid hinge, and provides an isolated mount for the A/C line clamp. The studs are moulded into the rubber on each end, which is brilliant.........
The stud on mine had ripped out of the rubber, so I ordered a replacement. This part had evidently failed within a week of the car's delivery back in '85, because I noticed that the A/C hose has worn almost completely through from rubbing on the lip of the engine bay when the lid is opened and closed. This mount secures the A/C line, and is supposed to keep it from doing just that.
I installed the new part, and was concerned that there was a tremendous amount of tension on it, due to the routing of the A/C line. Well, one day later, and the stud has already sheared from the rubber, leaving the A/C line unsecured, and rubbing against the sharp edge of the engine bay again.
Why would you design a part in this fashion, when it's under so much stress from the whacky routing of the A/C line? After replacing it, I knew it wouldn't last a week. Looks like a custom part is needed......
Yeah, yeah, I know, Porsche's ain't supposed to have A/C in the first place, but I'm still running my A/C here in FL...........
Michael
'98 Boxster in Ocean Jade Metallic
Old 11-25-2003, 10:03 AM
Student of the obvious
LeeH's Avatar
When mine broke I dug through my garage cabinets and used a long bolt with a piece of black rubber hose as a spacer. It works the same, looks the same, will never break again, and best of all - cost nothing.
Lee
Old 11-25-2003, 10:23 AM
The superior intellect of the Porsche engineers strikes again. Must be the same guy responsible for the headstuds.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-25-2003, 11:25 AM
scottb's Avatar
I had a similar part on the exhaust system of my old Jensen Healey. It broke. My fix was the same as Lee's....a long bolt left a bit loose.
1984 Targa
Old 11-25-2003, 12:00 PM
I recently replaced the AC lines in my 87 and although all the little holders were still intact (including part 24A - which I agree is a very poor design) the old lines were very badly worn at the deck lid edges. When I replaced the lines I went out and bought a few of those wrap around plastic hose protector sleeves at NAPA Auto for a few bucks each. This is a much better way to protect the lines from the sharp sheet metal edges.
Bill
Old 11-25-2003, 12:46 PM
Double Trouble
targa911S's Avatar
What IS air conditioning?
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 11-25-2003, 01:23 PM
Binge User
Schrup's Avatar
It's that 80lbs of crap I ripped off my car last week. But then again I don't live in Florida
Paul
Old 11-25-2003, 01:34 PM
Is this the same part that is also used between the air pump mounting arm to the fan shroud mounting bracket? Sure does look the same.
Howie
79SC
Old 11-25-2003, 09:57 PM
..P ..P is offline
Buy a K&N filter, that way you can flush $57 down the commode, get nothing in return except more dirt in the motor. Now THAT's a deal!!
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 11-26-2003, 06:53 AM
those type of mounts are called "lord" mounts. Available from McMaster-Carr http://www.mcmaster.com/
Check page 1210.
Another tip to not use locking type nuts on them as they wont live long if twisted upon installation...
Chris
Old 11-26-2003, 08:03 AM
Mine was rubbing along the deck lid opening too, I just slightly bent the pipe downward a little and VIOLA!!
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 11-26-2003, 12:55 PM
scottb's Avatar
Does anyone know which of the McMaster mounts is equivalent to the Porsche mount?
1984 Targa
Old 11-26-2003, 02:46 PM
Jeff Alton's Avatar
If this is what you need, send me your address and I will mail it out to you free of charge.
www.turn3autosport.com
Old 11-26-2003, 03:40 PM
