What tool do I use?
What tool do I use to loosen bolts in Pic. I need to adjust my door. I have tried torx and star tools with no luck. Any help would be appreciated thanks, Sam
Unregistered
You need what is called a triple square wrench. Same style as the CV joint bolts.
But based on the look of them you may need to use a drill bit if they are stripped too bad. |
I would start by ordering new bolts, then I would use a dremel to cut a nice slot across the bolt, and finally use a wide-blade srewdriver to remove the old bolts.
Thanks Sammyg2, do you know where I can find one? I doubt they have one at Sears.
Sam Gonzales '69 912 2.0 -6 power |
Unregistered
It depends on what size you need.
I purchased a triple sqaure for the CV joint bolts at a local VW shop for around $8. I think it was an 8mm. Have you called pelican to see if they have it? They might surprise you by either having it or being able to get it fast. |
I found a set of four (6mm through 12mm) at Autozone. They had an odd name like 'internal wrench' on them.
Chris.
'95 993 C2 '86 911 (sold) |
12 point set at Sears, or Kragen, for little money
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I had one of these tools that went to my 911 flywheel on back order from a local Snap-On dealer.
After 3 weeks, I called Pelican by phone, and they had one at my door within 3 days for less $$ than Snap-On.
-Rickeolis- 1986 Corvette |
Same as CrisL found them at Auto Zone
Ken Copeland 70 GT6+ KC78784 70 Spit FDU84919 70 GT6+ KC81551 (Ok so I like 70s) 71 Porsche 911T 00 Chevy Pick UP |
It looks just like this.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks Guys, I found one at the local VW shop. Too bad the bolts are to stripped to use it. Sam
Use an impact screwdriver with a 3/8 drive for your 12 point. The bolts will start out.
Got my 12 pt 8mm (like the picture posted by catca) at Santa Fe Tools on Central, near intersection of Wyoming (Abq. NM))for about $3. They have lots of strange tools. Sorry I didn't see your post or you could have borrowed mine.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Senior Member
Re: What tool do I use?
They look stripped. You do need that special socket (CV bolt-type) as previously mentioned. If you can use it with a hammer impact driver, you might get lucky.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
If no luck with a 12-pt. bit, the right size easy-out (spiral) bit should do the trick (with a 1/2 ratchet or breaker).
Yep, they sell them at many auto parts stores, they have been used on everything from old Pinto's, volkswagons, Chyslers with VW engines (frt drive water cooled), etc....
As said before, they should be called a "triple square".
