sammygon1's Avatar
What tool do I use?
What tool do I use to loosen bolts in Pic. I need to adjust my door. I have tried torx and star tools with no luck. Any help would be appreciated thanks, Sam
Old 11-26-2003, 01:19 PM
Unregistered
sammyg2's Avatar
You need what is called a triple square wrench. Same style as the CV joint bolts.
But based on the look of them you may need to use a drill bit if they are stripped too bad.
Old 11-26-2003, 01:24 PM
I would start by ordering new bolts, then I would use a dremel to cut a nice slot across the bolt, and finally use a wide-blade srewdriver to remove the old bolts.
Old 11-26-2003, 01:26 PM
sammygon1's Avatar
Thanks Sammyg2, do you know where I can find one? I doubt they have one at Sears.
Sam Gonzales
'69 912 2.0 -6 power
Unregistered
sammyg2's Avatar
It depends on what size you need.
I purchased a triple sqaure for the CV joint bolts at a local VW shop for around $8. I think it was an 8mm.
Have you called pelican to see if they have it? They might surprise you by either having it or being able to get it fast.
Old 11-26-2003, 01:30 PM
I found a set of four (6mm through 12mm) at Autozone. They had an odd name like 'internal wrench' on them.
Chris.
'95 993 C2
'86 911 (sold)
Old 11-26-2003, 01:32 PM
12 point set at Sears, or Kragen, for little money
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-26-2003, 02:49 PM
rickeolis's Avatar
Porsche Crest PELICAN!
I had one of these tools that went to my 911 flywheel on back order from a local Snap-On dealer.
After 3 weeks, I called Pelican by phone, and they had one at my door within 3 days for less $$ than Snap-On.
-Rickeolis-
1986 Corvette
Old 11-26-2003, 02:55 PM
kcope's Avatar
Same as CrisL found them at Auto Zone
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 11-26-2003, 02:56 PM
Jeff Alton's Avatar
It looks just like this.
www.turn3autosport.com
Old 11-26-2003, 03:38 PM
sammygon1's Avatar
Thanks Guys, I found one at the local VW shop. Too bad the bolts are to stripped to use it. Sam
Sam Gonzales
Old 11-26-2003, 04:50 PM
Zeke's Avatar
Use an impact screwdriver with a 3/8 drive for your 12 point. The bolts will start out.
Old 11-26-2003, 05:03 PM
Send a message via AIM to fintstone
Got my 12 pt 8mm (like the picture posted by catca) at Santa Fe Tools on Central, near intersection of Wyoming (Abq. NM))for about $3. They have lots of strange tools. Sorry I didn't see your post or you could have borrowed mine.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-27-2003, 11:33 PM
Senior Member
Doug Zielke's Avatar
Re: What tool do I use?
Originally posted by sammygon1
What tool do I use to loosen bolts in Pic.....
A torch
They look stripped. You do need that special socket (CV bolt-type) as previously mentioned. If you can use it with a hammer impact driver, you might get lucky.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-27-2003, 11:38 PM
Eric Coffey's Avatar
If no luck with a 12-pt. bit, the right size easy-out (spiral) bit should do the trick (with a 1/2 ratchet or breaker).
Old 11-28-2003, 01:59 PM
Yep, they sell them at many auto parts stores, they have been used on everything from old Pinto's, volkswagons, Chyslers with VW engines (frt drive water cooled), etc....
As said before, they should be called a "triple square".
Old 11-28-2003, 04:45 PM
