Author of "101 Projects"
It works - pretty well. I meant to switch this over and try it when we went to a dedicated search server last year, but completely forgot about it, until I tried to search for CIS tonight, and realized that the server was set to only index 4 characters and greater.
This should be a big improvement. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
or something like that.
72T Sepia, Irish delivery car ; '16 Cayenne Gone ... 73E Targa - Grey/Beige ; '90 964 C2 - Samtrotmetallic (Gina, the Lipstick Lollobrigida) |
No offense intended to the search method embedded in the forum. But I much prefer using this method:
(1) http://www.google.com/advanced_search?hl=en (2) input your search terms in related fields (3) in last field: "Search within a site or domain:" put "pelicanparts.com" I use to have problems with 2 characters and numerical numbers. So I just used this work around, and I found it's yielded better results sometimes than when I do pelican. I will say though, that pelicanparts forum title searches confined to a specific forum (for me 911 Technical and/or Rebuilding) are my favorite quick/easy way to search. Okay, now I just wasted another 3 minutes of my day. Hope it was of some use to someone. |
Make Bruins Great Again
You can use the other term for SC: POS
Mwuhahahahahaaaaaa!
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Formerly known as Syzygy
I suppose this should be an added incentive for people starting a thread to sorta describe the topic in the title. Makes it easier than searching for something located in "Oops, I pulled a boner" or something similar.
You can also attach an asterisk to a short search term (example: *SC) at this and other forums to force a search. Sometimes it works, sometimes it doesn't.
2018 911 Carrera coupe 1972 911T targa |
rick911s, that works great in this application and more ,thanks
76' 911s Signature Edition |
