Question Timing an E Cam
I am about to time the cams on my 911, I have E cams, a 70.4 crank, and S P/C's. I noticed that the E cams from 69-71 have a valve overlap of 3.15 and the 72-73 have an overlap of 2.9. Can anyone please explain why the difference, isn't an E cam an E cam regardless of year? What would you advise for my engine. Thanks for the help.
Old 11-28-2003, 07:49 AM
Cool
on p207 of Wayne's 911 Engine Rebuild Book is the part no. and timing for the different year E-cams.
The part no is the same for the 1969-71 & 1972-73 E-cams
The timing is different.
I did the early timing no, 3.0-3.3mm, because I'm using carbs and want an advanced cam timing......... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2003, 08:09 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Actually according to the BA book the early E cam is wilder than the later cam and thus the need for a different timing spec.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-28-2003, 08:37 AM
Cool
Originally posted by l33t9eek
Actually according to the BA book the early E cam is wilder than the earlier cam and thus the need for a different timing spec.
all I can offer it that before Pelican arrived in my world I ordered new E-cams from Stoddard.
and the Stoddard E-cam numbers match the numbers in Wayne's book.
So maybe the BA info refers to the E-cam timing....... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2003, 08:50 AM
"Actually according to the BA book the early E cam is wilder than the earlier cam and thus the need for a different timing spec."
Tim,
I'm confused by this statement. There is only one E cam. What earlier E cam is wilder than the early cam?
With a 70.4 crank, I'd go with the 2.9 mm spec. This setting should help the E cams which tend to run out of breath at higher revs. Low and mid-range torque should be sufficient using the long stroke crank.
Sherwood
http://members.rennlist.org/911pcars
Old 11-28-2003, 01:01 PM
Cool
ditto on Sherwood's comment..
I want it advanced for lower rpm torque curve.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-28-2003, 01:12 PM
Thanks Sherwood. I didn'y think there were different E cams. Sounds like the longer stroke makes the difference. Sorry for the double posting, I posted in this forum by accident as I thought I was in the 911 engine rebuilding when I posted. Thanks for the help...
Neil
Old 11-28-2003, 04:00 PM
