scca_ita's Avatar
Generic torque specs - various bolts
Are there generic torque specs for specific size bolts?
i.e.
4mm = ?ftlb
8mm = ?ftlb
10mm = ?ftlb
etc
My car is going back together this week and I was hoping not to look up specific torque specs.
Old 12-08-2003, 04:04 PM
Depends on metal of screw or bolt and the metal it is being screwed into. Jim
Old 12-08-2003, 05:17 PM
In the front or back of most manuals like Bentley or Haynes they will have torque specs
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-08-2003, 06:40 PM
vash's Avatar
with the effort you are about to put into the thing, why not spend the time to look up the torque values? heck just post your questions here, these people are great at giving up the values pronto.
poof! gone
Old 12-08-2003, 07:37 PM
AFJuvat's Avatar
As a general rule of thumb when no torque value is specified -
M6: 14NM
M8: 25NM
M10: 35 - 50NM
As a general rule, you do not want to exceed 14NM on fasteners that use a crush washer (like valve covers) - except of course, the drain plugs.
Double check specifications in the manual, torque values vary widely depending on the application.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-08-2003, 07:41 PM
HarryD's Avatar
A quick google search (http://www.google.com/search?q=bolt+torque+values&hl=en&lr=&ie=UTF-8&oe=UTF-8&start=70&sa=N) turned up many web pages.
Here's an interesting one:
http://dodgeram.org/tech/specs/bolts/M_bolts.html
http://dodgeram.org/tech/specs/bolts/SAE_bolts.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-08-2003, 07:48 PM
scca_ita's Avatar
HarryD, thanks.
I guess these are maximum torque values. Some are much higher than the specs I know off the top of my head.
Everytime I ask a Porsche tech about a torque value, they always seem to say: "Well thats a 13 MM so it should get xftlbs of torque"
So this is why I asked the original question about generic values.
Old 12-08-2003, 09:10 PM
Randy Webb's Avatar
speaking of being lazy... if there any general guide to the bolt size or nut size based on what size wrench fits it?
Old 12-08-2003, 09:45 PM
Early_S_Man's Avatar
Porsche Crest
For a torque chart ... go to the following site, then to Tech Info, then Section 10 -- Useful Info, then page 10-1027:
http://www.metricmcc.com/
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-09-2003, 12:54 AM
Irrationally exuberant
ChrisBennet's Avatar
Usually:
6mm bolts take 10mm wrenches
8mm bolts take 13mm wrenches
10mm bolts take 17mm wrenches
12mm bolts take 19mm wrenches
There are some reduced size nuts on a 911 motor. Some 915 transmissions are bolted to the motor with 10mm nuts that take a 15mm wrench. There's another nut like that that holds the rear engine bracket to the case. Exhaust nuts are another place you may find reduced size nuts i.e. 8mm that take a 12mm wrench.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-09-2003, 06:53 AM
HarryD's Avatar
Warren,
Very nice.
Harry
2020 MB E350 4Matic
Old 12-09-2003, 08:01 AM
Randy Webb's Avatar
Thanks, Chris.
Old 12-09-2003, 10:30 AM
