Thread size and Pitch for hard brake lines?
Hey All, Does anyone know the thread size and pitch for the fittings on the end of the hard brake lines? I'm planning on making some female ends that you can put over the lines while you have the calipers disconnected in order to stop brake fluid going everywhere. Thank you in advance!
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
I know the stock size for the hard lines on S calipers are either 10x1 or 11x1 I can't remember which. Not sure which brakes you have or if they're the same.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Irrationally exuberant
They are 10x1. I have been looking for caps for this application and all I can find are plastic ones. I would love to to have 4 caps.
![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hey, Thank you both. Chris, I will make some tomorrow and I can get them to you on Sat. if you can come. If not, I'll ship them to you.
Cheers, James Chris, if you can't make it do you have a jack thingy I can borrow for my engine drop? Michael said he could pick it up from you tomorrow at lunch. Cheers, James
James,
No rush on the caps, I'll be seeing you at some point this winter if I don't come down for the engine drop. I'll be doing a couple of motors this winter, maybe you can come up for one of those? I'll email you about the jack thingies. -Chris
As Chris stated 10x1.0
What caps are you looking for Chris?
If you have alloy S calipers, use the brake bleed valves on the top of each caliper. It worked for me.
Edit... I connected them to the end of the soft lines.
Neil '73 911S targa |
