Senior Member
ohecht's Avatar
Are Loctite and Permatex the same?
Are these brands the same company or product?
I have been unable to find the Loctite 518 I have had great results with before on my transmission flanges, but I found Permatex 51817, which is described as the same product, but is blue rather than red.
To complicate things more, Loctite also has part number 51817 for a specific size of the 518 material.
Are these things identical?
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 12-11-2003, 05:20 AM
TerryBPP's Avatar
Noooooooooooo! Loctite is for securing bolts permanently. Permatex is a sealer for gaskets. They are nothing alike. What are you using it on?
Old 12-11-2003, 05:33 AM
Cool Re: Are Loctite and Permatex the same?
I'm not sure what's going on
but the info says
purple for low strength
blue for med strength
red for high
and the container says " Man. by Permatex"
I think the last 2 dig of the 5 dig no. is for size........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-11-2003, 05:42 AM
Loctite not only makes stuff for securing bolts but a whole range of gasket materials. Loctite 574 for instance is recommended for sealing the crankcase.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Friend of Warren
Yes both Loctite and Permatex make sealers and threadlockers.
Kurt V
Old 12-11-2003, 06:28 AM
Somewhere in the Midwest
MotoSook's Avatar
This was discuss not to long ago. There is a thread here and in the rebuild forum.
Basically, use the Loctite stuff.
Old 12-11-2003, 06:32 AM
Here's a discussion on this topic: Loctite vs Permatex equivalency
Warren & Ron, may you rest in Peace.
Old 12-11-2003, 06:43 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
The permatex red isn't bad for threadlocking head studs, and i used the green on a loose bearing race in the trans and it locked it up real quick.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-11-2003, 06:53 AM
Irrationally exuberant
ChrisBennet's Avatar
I get my Loctite 518 from NAPA.
PepBoys carries Permatex products.
My bottle of Permatex Medium Strength Thread Locker Blue Item #2424 say "Manufactured for Permatex by Loctite Corp" on the back.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-11-2003, 06:56 AM
Loctite is the company behind the technology, they make and sell all their stuff via distributors.
Permatex is a brand used by another company to sell some of the same products.
So, Permatex products are loctite products, but not vice versa.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-11-2003, 07:12 AM
Detached Member
Hugh R's Avatar
My understanding is you don't use the red unless you NEVER-EVER want to take it apart again. My brother works at the Jet Propulsion Lab near Pasadena and he says that JPL doesn't allow the red to be used on satellites that get shot out of the solar system, because they might want to take something apart before it goes.
Hugh
Old 12-11-2003, 10:07 AM
Senior Member
ohecht's Avatar
I am surprised the NAPAs here don't have Loctite 518, only Permatex 518, and that the Permatex is blue while the loctite is red.
Olivier
Olivier Hecht
1982 911SC
Old 12-11-2003, 10:53 AM
"I am surprised the NAPAs here don't have Loctite 518, only Permatex 518, and that the Permatex is blue while the loctite is red."
Let's not confuse a gasket sealer with a thread locking compound.
Permatex 518 and 574 are gasket-type, aneroebic sealers.
Loctite Red, Blue and Green are thread locking compounds which may also have Permatex labeling. Red, Blue and Green also have their own ID numbers. Loctite has more related products for fitting parts inside another.
Sherwood
http://members.rennlist.org/911pcars
Old 12-11-2003, 12:56 PM
Senior Member
ohecht's Avatar
I am definitely referring to the Permatex 518, which is an anaerobic gasket maker and is blue in color, while the LocTite 518 I had was also the anaerobic gasket maker but was red in color.
Olivier
Olivier Hecht
1982 911SC
Old 12-11-2003, 02:51 PM
I've used red on lots of things that I've taken apart again.
I don't think you'd want to use it on little tiny nuts and bolts, but on the larger pieces, I've never had a problem loosening the bolt/nut.
Old 12-11-2003, 04:40 PM
Hi Olivier,
I believe 574 is not marketed for our shores; I haven't seen it advertised in domestic industrial supply houses; and only in a few automotive supply houses.
The Permatex/Loctite 518 is the domestic counterpart to 574. I understand it works well too and is the gasket sealer of choice for many manufacturer's metal-on-metal applications. The situation is that the 911 crankcase is the very first part to assemble (other than the oil pump) and the amount of work involved to not return to this area requires a sealer with known and proven qualities. However, I'm sure there are success and failure stories for every brand of anaerobic sealer. For many folks, maybe it's equal parts sealer choice, surface preparation and ..... luck.
Sherwood
Old 12-11-2003, 04:50 PM
Senior Member
Doug Zielke's Avatar
Originally posted by 911pcars
I believe 574 is not marketed for our shores....
Maybe, but I got a bottle of the real thing (German writing on the label) from my friendly Porsche stealer.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-11-2003, 04:55 PM
Doug,
I meant for normal consumer use. Porsche owners aren't normal ....... consumers.
Sherwood
Old 12-11-2003, 05:06 PM
