no spark
ok, I know this has been brought up before, took motor and tran. out to replace clutch, put evrything back the right way?????
and now I have no spark? did notice that the ground wire from tran. to body was broke, didnt think that would stop spark? anyone got any ideas. thanks mark
Old 04-30-2004, 03:10 PM
Put that big fat ground wire back.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-30-2004, 03:16 PM
kqw kqw is offline
What model Porsche are we talking here?????
The Fox
Carrera
Old 04-30-2004, 03:37 PM
MY83SC's Avatar
Tell us mooooore...............
Mike
83 SC
Old 04-30-2004, 05:46 PM
sorry 1970 911 targa 2.2. also seems like when I touch points or anything around the points it zaps, like the whole dist. is charged. this is when checking to see if I open and close points do I get a spark,
anyways I dont get a spark accross points?? will put big ground wire back on today will update all thanks again mark
Old 05-01-2004, 03:46 AM
kqw kqw is offline
Check the installation of your condensor. Make sure it's attached correctly.
The Fox
Carrera
Old 05-01-2004, 11:14 AM
condensor should be on left hand side of engine ?
mark
Old 05-02-2004, 04:24 AM
Early_S_Man's Avatar
Porsche Crest
The condensor should be either inside or attached to the distributor ... but, only if you have a conventional -- battery- coil ignition!!!
Your car SHOULD HAVE a Bosch CDI system, and that system does not have a condensor accross the points!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-02-2004, 07:37 AM
