Somatic Negative Optimist
Gunter's Avatar
SprintStar: The Porsche engineers took all of that in account when they set the suspension. Even though the fender lip measurments might make you think that now the front is higher, in fact, with 25"front/24.5"rear, the one deg nose-down attitude is obtained. Put a protractor on the door sill and you'll see. Too many people sacrifice good handling characteristics with the exaturated lowered look. Lowering at any price to be cool. But, I have seen 911s with factory specs run circles around these lowered wonders. You really need to know what you are doing when changing the suspension dynamics. Wacking it down and getting a loud muffler is good for driving the chicks to a disco but not so good for real performance. What's more important?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-04-2004, 05:52 PM
Herr Gunter, I think you misunderstood me. The PO did set my front MUCH lower than the rear. I believe Katie is now about 25" front/26" rear. Would this help in a SWB car to transfer more weight in front or 25"front/24.5"rear is still best?
Chicks in a disco? Nay... Don't care much for them!
Sprint.
P.S I'll check out the 1° nose down when I get a chance with a protractor. I think I might have as much as 2 or 3° as she sits now!
Old 01-05-2004, 01:09 AM
Gunter's Avatar
O.K. I don't know what SWB 911s would be set at to have it lowered and still enjoy good handling characteristics. The '74 to Carrera years seem to have good results with 25F/24.5R with the bump steer kit installed. I believe that the SWB 911s don't have camber adjustments in the shock towers, so, when you lower these, the camber would be extremely negative. That way, your front tires are running on the inside edge. How can this be corrected on the earlier 911s? Maybe some SWB owners can chime in here. Cheers.
Old 01-05-2004, 10:17 AM
dickster what size tbars did you use in the back????
Old 01-05-2004, 09:15 PM
dickster's Avatar
i have just installed 31mm bars.
nice and firm (but not harsh), love 'em.
Rich
'86 coupe
"there you are"
Old 01-06-2004, 05:51 AM
D idn't E arn I t
RANDY P's Avatar
Rich -
what was the final height you came up with? Car looks great...
rjp
AOC/Hogg 2028
Old 01-06-2004, 10:06 AM
it is down to 24 but i am trying to find out if i need to get bigger t bars for just the street?????
Old 01-06-2004, 10:13 AM
D idn't E arn I t
RANDY P's Avatar
If you can afford it now, do it.
AOC/Hogg 2028
Old 01-06-2004, 10:15 AM
will it help on the street a lot??
Old 01-06-2004, 10:24 AM
D idn't E arn I t
RANDY P's Avatar
It's an enhacement if you drive hard, you'll appreciate it. As whether or not the car will survive as is- stock will be fine. (Despite what all the doom and gloom types say)
rjp
AOC/Hogg 2028
Old 01-06-2004, 11:31 AM
dickster's Avatar
randy,
thanks.
i got 24/24.5 in the end - very pleased with it.
Rich
'86 coupe
"there you are"
Old 01-06-2004, 11:43 AM
Senior Member
Leland Pate's Avatar
You know... it is not very well known that NASA uses this same system as a means of measuring critical space orbiter components!
Where did you pick up that tip???
WOW!
Chief Architect and Mastermind,
SCWDP
Old 01-06-2004, 11:49 AM
thanx, i am good like that (nasa) here i come.
Old 01-06-2004, 02:56 PM
jyl jyl is online now
jyl's Avatar
You don't "need" larger torsion bars for normal street driving. My car is lowered - not as far as yours, I think a bit under 25" in front - and its not like the stock t-bars leave the front end dragging or anything.
I may end up putting in bigger torsion bars but I've also got sport shocks, polybronze bearings, and monoballs in it and I'm still going to do some AX and DE with the new stuff before finally deciding on stiffer bars. I'd like to use the most compliant suspension I can and still get the handling I want.
Old 01-06-2004, 05:07 PM
Hi Gunter! How was the week?
My SWB has recently received a suspension upgrade with RSR struts and later front end. I got camber plate in the towers too. So if anything, my SWB is like a later 911, save for wheelbase differences.
Maybe some racer dudes here would share their SWB suspension settings? Thanks.
Sprint.
Old 01-09-2004, 12:18 PM
