Help with Fuchs outer lip problem
I did my post season cleaning of the inside of my Fuchs today and I tried a new cleaner. Needless to say, I 'm now panicking over the condition they look now. I saw in previous posts that Vasoline makes the Black look better, but will it remove the streaking? How do I remove the cloudiness from the outer ring. Am I doomed? Please be gentle, I'm feeling bad as it is.
Thanks for your time. Weaver
Weaver '88 911 Targa '03 911 Turbo, X73 Susp. '13 Panamera GTS PCA member Central Indiana |
I forgot to post the pics.
Vaseline worked for me with a similar issue. However, polishing to a mirror finish is my current mission to combat the problem.
Nate Gone: '86 Carrera coupe Current: a $75 BMW 320i |
My understanding is that vaseline is for the outer lip ONLY, not the black painted paddles. In speaking with the guys at www.carcareonline.com, they suggested washing the black, then hit it with 3M hand glaze, then wax that portion. They said it was a painted surface and wax was the best at protecting paint.
hope this helps - doesn't look like you did any permanent damage to the wheel. BTW, what did you use?
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Unregistered
I heard that vaseline was used on the black painted portion to try and make it shine. it is after all a matte finish. Al Reed says he used pledge furniture polish on it.
To make your outside (unpainted) lips less cloudy you need to use something like mothers aluminium polish to try and bring it back. I use wenol red to clean and blue to maintain. Both are available from Pelican I think. It will not shine like chrome but you will be able to improve it with plenty of elbow grease. If you want it to really shine you will have to get more aggressive with it as detailed in some of the articles at http://www.pelicanparts.com/911/911tech_articles.htm Last edited by sammyg2; 12-17-2003 at 03:24 PM.. |
I believe that vasoline works well to clean the anodized surface (black or not) of a fuchs wheel. I would not use it on a painted surface myself. You would follow with wax after cleanining off the vasoline residue. I would not use a polish on an anodized surface. If a wheel is painted, then you would treat the surface as paint If polished (unless clearcoated) treat as aluminum.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
First, I just wanted to thank everyone for their help and input. I have only asked a few questions on this site and usually never get an answer. Sometimes I felt like I needed to be one of the regulars to get an answer, but y'all have been very kind.
Steve911- I don't want to say what brand I used but, its a family owned company and the CEO has a show on Speedvision and his first name is Barry. I used his "Gold Class" and applied it and washed it off in 15 seconds and not the prescribed 30 seconds on the label ( I timed it, I'm very anal ). I let the rims sit with the vasoline on them overnight in our guest bedroom so they would be room temp over night. Here are the before and after pics: ![]() ![]() The worst rim, which is the first and second pic, is still barely hazy, but much, much better. How long will this last? A previous post said to do it weekly until the cloudiness is gone. Is this true? Again, thank you for your help. Weaver
Friend of Warren
Weaver I had similar "before" wheels and have always used vaseline on both the anodized rim and black spokes with no problems. I did the vaseline routine about once a month. Put a good coat on with one old t-shirt, let set for how ever long you feel like waiting, wipe excess off with another t-shirt and then buff out with a clean t-shirt.
Kurt V No more Porsches, but a revolving number of motorcycles. |
