goodbye polished fuchs....
Ok, this maynot be a fashionable move these days, but I want to return my polished centers back to the stock black insets. I have 8's in the rear, 7's up front.
Questions:
Is there a spec for the factory black color? (trim black? matte finish?)
Whats the best way to prep the polished anodized surface before paint (sand/blast/etch/etc.)?
Can I paint the polished caps black also (or should I buy black factory ones...)?
Thanks guys...
fucherman
Old 12-18-2003, 09:42 AM
Harlan Chinn's Avatar
You might try to trade with someone that wants polished paddles for their stock finished fuchs.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 12-18-2003, 09:57 AM
FenderGuy's Avatar
fucherman whats wrong with your polished wheels? I want to get my fuchs polished and was wondering how come your going back to stock color?
Old 12-18-2003, 01:28 PM
FenderGuy's Avatar
fucherman you have a pm
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 12-18-2003, 01:30 PM
Mark Wilson
Guest
Posts: n/a
Krylon Satin black works fine.
Old 12-18-2003, 01:36 PM
RETIRED
Joe Bob's Avatar
Wurth's Satin Black is the anal retentive weenie acceptable color....
2012 ML350 3.0 Turbo Diesel
Old 12-18-2003, 01:42 PM
Gon fix it with me hammer
svandamme's Avatar
i prefer black too , looks more agressive than polished IMHO
Stijn Vandamme
BIMDIESELBMW116D2019
FenderGuy's Avatar
Old 12-18-2003, 03:31 PM
You MUST bead blast or use some type of abrasive media prior to painting a polished wheel. Take it from someone that knows. I painted mine and had them chip due to the lack of bond of the Wurth with the polished areas, even after using self etching primer. Next, I masked and blasted them leaving a nice rough surface and painted again. If not blasting, use 220-300 wet-dry paper. It has held great now.
Old 12-18-2003, 04:51 PM
definately
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-18-2003, 07:58 PM
polished then powdercoated black (center) then powder cleared over all.
Old 12-18-2003, 09:32 PM
alf alf is offline
alf's Avatar
I like black or full anodized better. Polished is a little too bling for me.
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 12-18-2003, 09:45 PM
Polished fuchs are quite easy to keep clean but they do attract a lot of attention when the sun is out.
Does the black powercoat crack and fall out when the lug nut is tightened against the wheel? What happens to the clear powdercoat over time, will it begin to yellow or will it stay clear? What's better chips in the clear powdercoat or dings in the polished metal?
Harlan Chinn
Old 12-18-2003, 10:11 PM
