goodbye polished fuchs....
Ok, this maynot be a fashionable move these days, but I want to return my polished centers back to the stock black insets. I have 8's in the rear, 7's up front.
Questions: Is there a spec for the factory black color? (trim black? matte finish?) Whats the best way to prep the polished anodized surface before paint (sand/blast/etch/etc.)? Can I paint the polished caps black also (or should I buy black factory ones...)? Thanks guys...
fucherman |
You might try to trade with someone that wants polished paddles for their stock finished fuchs.
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
fucherman whats wrong with your polished wheels? I want to get my fuchs polished and was wondering how come your going back to stock color?
fucherman you have a pm
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Guest
Posts: n/a
Krylon Satin black works fine.
RETIRED
Wurth's Satin Black is the anal retentive weenie acceptable color....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Gon fix it with me hammer
i prefer black too , looks more agressive than polished IMHO
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
You MUST bead blast or use some type of abrasive media prior to painting a polished wheel. Take it from someone that knows. I painted mine and had them chip due to the lack of bond of the Wurth with the polished areas, even after using self etching primer. Next, I masked and blasted them leaving a nice rough surface and painted again. If not blasting, use 220-300 wet-dry paper. It has held great now.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
![]() polished then powdercoated black (center) then powder cleared over all. |
I like black or full anodized better. Polished is a little too bling for me.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Polished fuchs are quite easy to keep clean but they do attract a lot of attention when the sun is out.
Does the black powercoat crack and fall out when the lug nut is tightened against the wheel? What happens to the clear powdercoat over time, will it begin to yellow or will it stay clear? What's better chips in the clear powdercoat or dings in the polished metal?
