looking for a triple square socket for axle bolts..
i figured i could just go to sears, but not luck.
any suggestions for a place that carries triple square sockets for the axle bolts to the trans? im in chicago...
i found some online but was hoping to do the work this weekend.
thanks!
-bernie
Old 12-20-2003, 10:00 AM
Autozone has them. They call it (oddly) an internal wrench set. I can look up the part # if you want.
Chris.
'95 993 C2
'86 911 (sold)
Old 12-20-2003, 10:13 AM
chris,
i'll call around to see if they have it in stock nearby... thanks!
-bernie
Old 12-20-2003, 10:29 AM
Unregistered
sammyg2's Avatar
I got mine at a local VW high performance shop.
Old 12-20-2003, 10:31 AM
North Coast Cab's Avatar
Bernie,
Crawl under there and make sure you need it. Many cars of our vintage have already had their CV's repacked and the bolts changed to allen style. Our host has the socket if needed.
John
1985.5 944 GTS
Old 12-20-2003, 10:52 AM
Send a message via AIM to Oldporsche
Cool
Auto parts stores carry them in their Lisle tool catalog or the K-D tools. Actually they are common in a lot of stores.
First make sure that you need them.
Good luck,
David Duffield
Old 12-20-2003, 11:00 AM
At Autozone, the brand is OEM and the part number is 25015. That's for a set of four -- 6, 8, 10 and 12 mm triple square drives. You'll need a 1/2" socket to use with them.
Chris.
'95 993 C2
'86 911 (sold)
Old 12-20-2003, 11:32 AM
Isn't "12 points" another name for them. Got them at AutoZone.
Old 12-20-2003, 12:12 PM
i called 4 autozones and none had them in stock... ended up going to Murry's Discount Auto... woooo hoooo. holiday traffic sucks... but being in the city, i have 20 auto stores in a 3 mile radius.
I'm sure I need them because the new axles i ordered also come with new bolts with that type socket required.
I'll admit, sometime aquiring tools stumps me... its not like hardware stores carry good tools. Going to Sears is a pain as you wait 20 minutes to find someone to unlock the 'case', only to find the don't have the right metric tool... ordering online is tough if your current project suddenly calls for a new tool.
thanks for the suggestions and letting me vent.
-bernie
Old 12-20-2003, 01:46 PM
My new bolts from Wayne were allen head.
John
1985.5 944 GTS
Old 12-20-2003, 01:53 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
They are also called "ribe" sockets.
Marc
Old 12-20-2003, 08:27 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Got mine at Pep Boyz in Orland Park.
Made by Lisle like old_porsche said.
Kevin L
'86 Carrera "Larry"
Old 12-20-2003, 08:44 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
http://buy1.snapon.com/catalog/pro.asp?tool=all&Group_ID=282&Group_Name=Triple+Square+%2F+Standard%2C+mm%2C+chr ome&Sub_Cat_ID=2026734&Sub_Cat_Name=Socket+Drivers&Cat_ID=2026673&Cat_NAME=3%2F8%22+Drive&store=snapon-store
I got mine from the snap on guy...unfortunately no 12mm though.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 12-20-2003, 08:58 PM
