Monoball to replace ball joint in front a-arm
I have been told by several different people to replace the ball joints in the a-arms with monoballs for dedicated racecars. I was wondering if anyone could tell me the advantage to doing so as it appears that the stock ball joint can’t deform under load and the height of the stock ball joint is not that much different from the monoball when installed. Thanks
Old 12-23-2003, 05:11 AM
don911's Avatar
I've never heard or seen anything that replaces the ball joint with a monoball. Doesn't mean it doesn't exist though.
For the front, the only monoball I know of replaces the upper strut mount fitting with a monoball fitting.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 12-23-2003, 05:28 AM
Ahhh.....hmmmm...couldn't the lower ball joint be considered a "monoball" joint in the first place ???
I think the original poster might be referring to the upper shock mount, originally in rubber..to be replaced by a monoball. That would make more sense.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-23-2003, 05:43 AM
No, I am aware of the monoball setup for the top of the struts. I already have camber plates that include these. I am referring to the modification to the A-arm to use a monoball instead of the ball joint. For instance, the ERP front A-arms come with this option.
Old 12-23-2003, 05:48 AM
Licensed User
Shuie's Avatar
Thats what I thought. How is the ball joint in the a-arm different from a monoball?
Old 12-23-2003, 06:21 AM
Senior Member
Superman's Avatar
I agree. The ball joint is already a monoball. Same with the Turbo Tie Rod ends.
Mocha 1978 911SC. "Coco"
Old 12-23-2003, 06:28 AM
Elombard's Avatar
See the add in Excellence this month. First time I had seen it. Definitely a beefier piece than the factory ball joint. Actually it might have been the Kanna racing (sp?) web site where I saw it?? I will look around and post it when I find it.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-23-2003, 06:34 AM
Platinum Member
dad911's Avatar
VCI replaced my lower joint with a Heim Joint. This allows additional camber adjustment.
Old 12-23-2003, 07:03 AM
ttweed's Avatar
This is correct- Kevin from Kanna posted the following to the Rennlist a few days ago:
Althought the web page is still under construction, I have some of our products up. Check it out at www.KannaMotorsports.com
Now available are the KMS-Ohlins double adjustable strut for 911's with user adjustable spindle height. I also have a pic of the KMS Monoball Balljoint. This is a must for any 911 racer using stock front control arm suspension. They are a direct replacemnt for stock 911 balljoints. $150 a set till the end of the year....
Also, our rear Monoball cartridges are $190 a set till the end of
2003 I have several more products in the works, and promise to keep the cost in check.
I am irritated at the way some companies over inflate their prices
just because they can.
Kevin Schilling
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 12-23-2003, 07:10 AM
dad911, I have talked to the people at VCI about this. I am curious, how do you attach the strut to the heim-joint? Do you have a stud welded onto the strut that runs down into the heim joint?
73 914-6 SCCA EP Race Car
71 911T - (In Progress)
67 911 - Not long for this world
Thank you all. You have been very helpful
Old 12-23-2003, 07:13 AM
Any been there done that opinions?
how does this piece feel/work in the real world?
brant
Old 12-23-2003, 09:15 AM
OK...I'll bite....maybe I'm dense...
If the "normal" ball-joint is a monoball...is this version simply larger with a bigger load carrying capacity...less distortion potential ? What's the theoretical rationalle behind all this?..
Wil Ferch ( feeling stupid... but honest with the question)
Wil Ferch
Old 12-23-2003, 09:51 AM
Chuck Moreland's Avatar
Dear Abbey,
I guess I'm feeling stupid too. The factory ball joint is a spherical bearing too, with no deflection, and is not known to fail frequently. I don't understand the benefit to this alternative part.
Plus the factory part has a weather seal and costs half as much.
Signed - confused in San Jose
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-23-2003, 12:19 PM
jyl jyl is offline
jyl's Avatar
From the website the balljoint-monoball looks much like the factory-balljoint, except:
- Maybe slightly larger diameter - can't be a huge difference though, they both have to fit into the same hole on the a-arm.
- No rubber seal - doesn't this location get pretty dirty in street use? (tho' I wonder why the rear monballs don't have rubber seals either.)
- Removable pin = another way to disconnect the strut from the A-arm - that could be handy, or another failure point to worry about.
Old 12-23-2003, 12:45 PM
Altogether...in my simple mind....a "net-sum-zero" kind of change, huh?
---Wil Ferch
Wil Ferch
Old 12-23-2003, 12:48 PM
Here is the answer provided to me from Kevin Schilling of Kanna Motorsports
“The Monoballjoint allows better front end control due to little if any
"give" in the ball, unlike the stock balljoint which rides on a plastic
insert.
We ran the stock balljoint and or Monoballjoint at Ohlins testing shake rig,
and the stocker deflected as much as .78 of a degree under load. The
Monoballjoint was a mere .016 degree!
Check out any Formula car....they all use monoballs.”
Old 12-24-2003, 03:41 AM
