Senior Member
Zendalar's Avatar
Which flare is installed correctly??? (PO intallation)
Well, I am proceeding the stripping of my car and i removed the FG flares recently.
The thing is that I noticed that...well...anyway, see the pictures, which one is correct position for the SC flares?`
This was installed by PO:
This is what i think it should look like:
What is your opinion?
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 12-28-2003, 11:41 AM
the torsion bar hole needs to line up with the torsion bar, so it can be removed if needed. eyeball center of the bar to center of the hole.
206 637 4071
Old 12-28-2003, 11:46 AM
Senior Member
Zendalar's Avatar
The hole is allright, but the fiberglass part, that I was pointing to...which one of the fiberglass parts is correctly positioned. On the lower image the torsion bar hole is right under the FG part.
You faintly can see the torsion bar hole in the picture, i tried uploading some images where I highlighted the hole, but I seem to be getting "page cannot be found"...
Projects:
Old 12-28-2003, 11:56 AM
CHILI's Avatar
I would find a stock SC and measure from the bottom of the window to the lip of the flare. Maybe a piece of string, so I can run along the shape of the flare.
But, I think the bottom one looks more correct, unless you have the car on jack stands. The top looks like it's too high. 4X4!
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 12-28-2003, 12:07 PM
I believe you have things correct in the second pic. In the first pic I see what looks like a part of a circle that should line up with the top edge of the torsion bar hole, but in the top pic it is no where near the hole, but in the bottom pic it looks lined up
Old 12-28-2003, 12:19 PM
Paul Valcourt's Avatar
The bottom picture looks closer to being correct. First you should remove your torsion bar hole cover. The part you are putting on shows a section of the holes edge that needs to line up with the original. The hole cover should go on after the flare is attached. If you are fiberglassing it on then you will probably have a lot of build up in that area so the cover may not fit so well. You might need to trim the flare back a bit around the hole.
75 targa 2.7
Lean and green
Old 12-28-2003, 12:32 PM
Senior Member
Zendalar's Avatar
Thanks This was my thought also, dunno why the flares where installed wrongly in the first place...
Projects:
Old 12-28-2003, 01:57 PM
