rdane's Avatar
R&P options?
"7:31 was available until 1975. The Carrera 3.0 had a 8:31."
Anything out there with even taller gearing for a 915 besides the 8:31? If so where do I find one? And are they as durable as the 8:31
Old 01-02-2004, 02:24 PM
Bill Verburg's Avatar
There was one that was marginally taller 7:27 but the difference isn't worth the effort and it is NLA anyway.
You'll need to use taller tires which is generallly what you are forced into anyway.
Bill Verburg
Old 01-04-2004, 01:17 PM
rdane's Avatar
Thanks Bill. I really appreciate the time you put in here to answer questions.
Another one for you when you have the time. I am running 225/45/17s and 255/40/17s.
I was looking to stretch my short gear box a bit with my new 3.4 since I will be able to more easily push the 17s. Is it better to just go back to a taller 5th like your set up for highway cruising? Could you repeat your tranny's gearing?
Old 01-04-2004, 04:30 PM
When you say short, 7:31? or 8:31 w/ short gears?
As always gearing is dependant on purpose and usage. Mine is geared(from memory which ain't so good these days) for 180 or so and gives a relatively relaxed rpm range at 60-90mph, but that's its main usage and it has unbelieveable torque.
The 964 enginew/ the same gearing was also nice and relaxed at a that speed level, but I felt that it was somewhat over geared(too low numerically) most of the time, not torqy enough to compensate. But ok for the track use because lower 3rd & 4th gears were used.
The 964 w/ 245/45x16 and stock C3 trans was about perfect for that engine.
So i'm guessing that you would likely not want to go any taller than a 255/40x17 @ ~25.1" tall if the 915/67 gears are used.
As a sidebar, There is a very interesting Michelin Pilot Sport tire(not Sport Cup) that is supposed to be available shortly, 265/35x17 @ ~24.3" tall which would suit your application very nicely. There is also a matching 235/40x17 @~24.4" tall
Thanks, its nice to hear that somebody appreciates the effort, too many folks don't even bother to reply w/ a thanks.
My gearing, I use a ~25.7" rear tire
Bill Verburg
Old 01-05-2004, 01:58 PM
