nostatic's Avatar
could it be that simple?
no idle today...coasted up into the garage after work. I poked around (the plastic bellows thing on the left above the air pump is for the heater, right? that shouldn't affect idle?), and pulled the airbox cover. I checked to make sure the pop off valve was seated and worked, and saw that a small part of the upper edge was a little rough (but not much). I reseated the airbox cover, strapped it up, and fired up the engine. Idle seemed OK. Dropped to about 800 for a second, then back up to around 900. Opening the oil cap dropped the idle like it should.
So it couldn't have been that easy to fix, right?
Old 01-07-2004, 05:21 PM
CHILI's Avatar
Re: could it be that simple?
Originally posted by nostatic
So it couldn't have been that easy to fix, right? [/B]
It's complaining because you took the duck tail off. See, I told you it should have been left on!
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-07-2004, 05:28 PM
Did you lift the flapper part of the valve & then reseat it? If so, the valve may not have been seating properly before.
Old 01-07-2004, 05:30 PM
HarryD's Avatar
my friend.. sometimes it is that simple (think occams razor). smile and enjoy
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-07-2004, 05:45 PM
Your do for an easy fix
Old 01-07-2004, 05:51 PM
Team California
speeder's Avatar
Exactly why I hate pop-off valves and don't have one. Not the place for a big vacuum leak. I've rarely seen one installed well enough to be 100% tight.
And yes I know about blown air boxes, but not much of a risk if motor and injection system is maintained properly, especially on late SCs.
Denis
Old 01-07-2004, 05:56 PM
Administrator
Jack Olsen's Avatar
You fiddled, and it's fixed. That means either you unintentionally solved the problem, or it's an intermittent failure. Either way, the result is that you get to (or need to) keep driving.
Old 01-07-2004, 06:13 PM
