Unconstitutional Patriot
What would you do with this Ebay engine?
Probably drive it sideways into a telephone pole 30 seconds from my house.....
'83 SC Coupe- Blk/Blk '03 Daughter- 10fingers/10toes |
Looks like a racing-only engine. With that kind of compression, and with intake and exhaust ports opened up like that, and with such an agressive cam...it would likely only be happy with carbs (as he had it set up) and at 4000rpm or more.
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
That's Chris Manfredi selling it. He's got an excellent reputation and races a GT1 turbo. I wouldn't hesitate to deal with him.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Senior Member
380 hp is quite a few for a NA 3.5L engine. It's possible, but an engine like this would have...ummmm.....attitude.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Super Moderator
380 HP with a 3.5L and only 10.5:1 compression?
They must rev the daylights out of that one.. Probably not that suitable for a street engine as I imagine the power band would have to be VERY peaky to hit those numbers. With the same setup, this would mean you'd be getting about 320HP out of an SC, or 270 out of a 2.5L motor...
MBruns for President
Jurgen - I think you answered your own question from the beginning.
Is a 380HP 3.5L engine even streetable? probably not very well...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I wrote the seller and he seems to remember that all of the head studs were Dilivar...for race use where the engine would come apart after the season, it was probably a wise move. Street use though...I'd have to think that this would be a headache to deal with in the future.
R/ Dustin |
At 3.5 Liters, I don't know what you could do with it excepting PCA GT? If it were 3.4 liters, it would be legal for SCCA GT2 at 2380 lbs. Anyhow, at 3.5 liters, I'm guessing that it's got a bore of ~102 mm and a stroke of 70.4 mm's. Given those dimensions and the port sizes, I'm guessing the peak HP is up around 7800 RPM. It might be a little lower, but the engine will need to be really good to be doing less the 7800 RPM AND turning out 380 HP. At that engine speed the ports are pulling about 103 meters per second which sounds reasonable, but fairly high so I would expect the HP to drop pretty fast after the peak. If you guess the peak torque of about 260 lb-feet 6000 RPM it would be consistant with the other numbers. At 7800 RPM the corrected piston speed would be about 4337 feet per minute which is a bit fast for a 911 on stock rods, but not completely outlandish considering that the '74 RSR had pistons speeds of about 4295 feet per minute.
The HP may actually be a little bit less then 380, but assuming that it is putting out what they claim, it would expect this motor to be VERY racy (as opposed to "streetable") with a fairly short life between rebuilds if you are using all of the rev's.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Seller said 100mm bore (I didn't ask for the stoke info), with a 7300 rpm redline...actually here is his reply (seems like a super friendly guy):
"Not sure origin of case:I think its 930. Case casting # 930.101.103.4R, serial #6290282 also has 930/04 stamped on case. Pistons and cylinders are Mahle...yes to Nikasil which refers to the material..not manufacturer. Bore size is 100mm. Rod bolt diameter is actually 9.2mm, and crank is new Porsche factory part. I never use regrinds on Porsche as I had a bad experience many years ago, and I don't trust them. The rods were all resized and x-rayed before installing. Yes to Carerra tensioners, redline to 7300." R/ Dustin |
Putting this engin in a street car sounds like
something I would do. The head work is somewhat agressive, the cams or stepping out there a bit. 100mm p/c puts it at the 3.5, 10.5:1 seems ok to me. High rev'en, will sound great! It's a solid setup, if your looking for a N/A powerplant it's a not a bad choice. Be a fun ride on the street or track!!
"Never go faster than you can stop" 85 - 930 (750hp) Norwood motec 3.5 twin turbo |
OK; Assuming that he is pulling peak HP at 7200 RPM and he's making 380 HP, he's generating BMEP's of about 198 psi which puts that engine in the same league as the Cosworth DFV late in it's development or the the 4.5 Liter 917 motor. Not impossible but...
On the plus side, I'd say that the port sizes are not grossly mis-sized and most likely aren't an issue if he hasn't messed up the shape. The 7300 RPM redline does not sound unreasonable in regards to piston speeds, even with a 74.4 mm stroke. It may still be a good motor, but I kind of doubt that it's a full 380 HP good motor. If the price is right and you're feeling lucky, why not?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 01-09-2004 at 11:04 AM.. |
Licensed User
It hit the reserve at $5k, I thought it would be much higher
Yeah, but it's missing a distributor and induction. That'll be another $4k
This unit definitely calls for 46 IDAs -- a set is closing on eBay right about now. It's not necessary to run it twin-plug, so you could get away with a conventional distributor.
Interesting alternative to the relatively trouble-free 3.6: easier to plug in; potentially more power (I don't buy the 380 number). I suppose you'd want to hook it up to a G50... Glad I have a few days to think about how this would work in my '72 coupe...
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Super Moderator
10.5:1... I'd either run twin plug with 94-95 octane or a good race gas... 103 or so to be safe on the hot days...
I think I'm beginning to drool again.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Certified Pre-Owned
Screw the motor, gimme what's behind it in the picture...!
The name in the window says "Stippler"
'84 Carrera Coupe |
Make Bruins Great Again
What would I do? Wet my jeans with joy the first time I stomped on the accelerator.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Senior Member
Guys,
The compression is not that big of a deal! The stock 4 litre V-8 motor in my 2000 Jaguar is 11:1 compression and its not a race motor! I do have to run premium fuel but its not peaky and while its very powerful its very smooth and easy to work with. A lot more concern for the street is what profile cams are installed in it. A motor that is lumpy and will not idle below 2000 rpms is not going to be one that a wife or G/F will put up with for long. Might be fun for us though! JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 01-10-2004 at 04:45 AM.. |
