CIS Injector Cleaning?
I suspect it's got to be very diificult to tell if your CIS injectors have the optimum spray pattern, or which ones may have some buildup present. Of course, replacing them every 50K or so would probably be a great idea and improve perf., but that can be a bit costly! Does anyone know if the injectors can be cleaned? I don't mean the fuel additive cleaning, but removing them and soaking them in some type of appropriate solvent to remove all deposits??
Philip 75 911S
Old 01-10-2004, 07:31 PM
vash's Avatar
do a search on this forum, there has been a bunch of chat about it. but on the contrary it is pretty easy to see if the spray pattern is good. you just pull them and get them to spray. you just missed some guy that posted his test here. it was last week (?). again another search.
poof! gone
Old 01-10-2004, 07:35 PM
vash's Avatar
found it:
Tested My CIS Injectors today
poof! gone
Old 01-10-2004, 07:37 PM
vash's Avatar
my only rust problem
here are some pics of my rust. i think the problem started along time ago when my stepdad refused to fix the front bumper rubber seal. is it tough to disassemble the front to check it out?
poof! gone
Old 01-10-2004, 07:49 PM
vash's Avatar
damn ! my first pic post and i friggen stick it in the wrong area. sorry.
poof! gone
Old 01-10-2004, 07:50 PM
