Sports Purpose 911 Driver
mjshira's Avatar
anyone run three way speakers in a 911?
I would like to run something like this in my car
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3070159585&category=32818
Has anyone done this? Or does anyone provide an enclosure to do so?
Thanks!!
James
Old 01-12-2004, 08:50 AM
Gon fix it with me hammer
svandamme's Avatar
might help to mention what type of 911 your drive.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-12-2004, 09:37 AM
Former Options Trader !!!
I never noticed that my cars have sound systems
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 01-12-2004, 09:50 AM
D Hanson's Avatar
I use three ways. I have a set of the Focal Utopias. Didn't like them too much. I actually like their Poly Keval 165 K2 woofer better, but the Uopia TN 51 tweeter is much better than the TN 47 that comes in the Poly Kevlar line. The Utopia mid is very transparent and nice, but the woofer is lacking low end punch in the 80 to 250 hz range.
The best sounding speaker in this price range is the Dynaudios. Also, Focal 165s are not exactly 6.5 inches so they may require enlarging the hole just a bit. Dynaudios also come in funky sizes but they just released a 6.5 inch compoenent set. I use the 7 inch.
90 C2 Cab Ruf Red/Blk
03 Caynne S L.Blue/Grey
03 996 TT Blk/Blk
04 996 Atlas Grey/Blk
Old 01-12-2004, 10:35 AM
mjshira's Avatar
thanks! where do you put the mid? would you consider emailing a photo?
James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-12-2004, 10:48 AM
BlkBird's Avatar
Would 3-way speakers be excessive?
I have 6" Diamond Audio components in the front, and 4" Diamond Audio components in the rear. Plus an itsy bitsy Boston Accoustic 8" sub. Seems to work well - and best of all the screws in the car haven't started to rattle yet!
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 01-12-2004, 06:14 PM
Sounds like Blk Bird's got the best setup. Your best off going with a set of component's front an rear and running a small sub. I really like the infinity perfect 10. It's very smooth and not that annoying bass that something like an MTX put's out. As far as components, I like the MB Quart's in my audi a lot. I paid a $100 per set and for the money they sound pretty good, plus ther made in germany. You should probably get an amp, most deck's dosn't really push that loud without distortion. You would also need an amp with the focal's.
Eric
Old 01-12-2004, 06:22 PM
D Hanson's Avatar
Caveat, I am the extreme when it comes to car audio and dropped well over $ 10k on the system in my 964 so alot of people would consider mine to be over kill. My systems are SQ and are not set to go boom boom, but they can be if I wanted them to. I, however, do rival home systems and can play loud and clean even over my cabriolet's engine sound with a cat by-pass, GHL primary and secondary bypass with the top down.
Big difference in high quality three way set especially if using an electronic crossover. Even with passive, each drive it operating in its optimal range. The mids will give most voice and they were be more efficient and hence clean focused on a set frquency range.
I run MB QSD with Esotec tweeters in the back. I swapped out by Esotecs that came with the Dynaudios for Scan Speak revelators, but the back is mainly for fill. You will get the best sound stage, imaging and clarity running a quality three way up front and a well blended sub from the rear without rear speakers. I only turn the gains up on my rear speakers when when the top is down.
My box is very shall and I have been relegated to using a very shallow sub (6 inch). I am now using a Diamond M6 Titanium which is very accurate and plays deep. This is an SQ sub, but it will hit very hard if you turn the gains up and hit it with some power.
If willing to go with Focal Utopias, I would not go with Diamond components. Too bright for my taste, but good spekaers for the price. Make sure you audtion both Diamond components to hear the tweeter and any Boston speakers. Boston are very colorful and the opposite of s Focal Utopia which is transparent and a nutral accurate reproduction of clean sound. Just not enough 80 to 250 hz.
If your interested in $ 800.00 dollar speakers, I would not try to steer you toward anything bu Dynaudio, CDT High Definition or better, McInotsh MSS 650s, Morrel, Rainbow, Lotus Series, Scan Speak, or Swan.
Here is table full of rejects that did not make the cut in various cars, many of which retail in the $ 700 to $ 1,000 range.
03 996 TT Blk/Blk
Old 01-12-2004, 07:00 PM
D Hanson's Avatar
Note, the $ 1,200 Focal Utopias on the bottom front to the left that didn't make the cut, along with the $ 1,400 McIntosh MSS 650s on the front row. There are also MB Qs $ 1,100, CDT High Defintions, CDT Carbo Fibre one speaker of which was never taken out of the plastic, Boston Pros and etc.
I am very Picky. I will audition speakers on one side for comparision test and etc. If you do not want to cut the third hole, go with the new Dynaudio 6.5 with the Esotec tweeter upgrade.
03 996 TT Blk/Blk
Old 01-12-2004, 07:05 PM
techweenie's Avatar
D Hanson: I have the tweets & woofs as I wait for my car to be finished. Any suggestion for a speaker to handle 500 - 3.5K Hz? I plan on a 4-channel amp driving the mid-bass directly and with passive crossovers on the 500-20K channels.
Thanks for any tips!
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 01-12-2004, 07:07 PM
Did you get the memo?
onewhippedpuppy's Avatar
D Hanson, you have more $$$ on your reject table than I have in my car! I bet your local car audio stores love to see you coming. Add that to the cars in your signature, my dear god man, could I have a little? Pity about your not being able to hear your 964 though, 10k in SQ audio equipment, and if I were to drive your car I'd turn it all off.
‘07 Mazda RX8-8
Old 01-12-2004, 07:49 PM
D Hanson's Avatar
techweenie: here is what I use in my 964.
http://www.woofersetc.com/product.asp?0=270&1=609&3=1331
$ 125 each.
Also check out www.madisound.com for great raw drivers if you already have grills.
Bought most of it off ebay and etc. and do most of the install stuff myself, but I am having shelves profressionally built for the 964 now because my sub amp is too large to fit. That's why I have that Pheonix Gold in there for the time being.
Stereo is on only half to 1/3 of the time. I took it out today to exercise it with the top down. I love to listen to it with the top down. I turned the stereo on for about the last 5 minutes of a 30 minute drive.
03 996 TT Blk/Blk
Old 01-12-2004, 08:15 PM
D Hanson's Avatar
On the Madisound page, check out the Accuton 2 inch mid ranges. They are about $ 200.00 each, but I have been real tempted to buy a set of these. They also have grill covers on them.
03 996 TT Blk/Blk
Old 01-12-2004, 08:17 PM
vash's Avatar
i was going to suggest some MB quartz, but i am not even qualified to be here. i wasnt here...damn that is some nice hardware..mr hanson.
poof! gone
Old 01-12-2004, 08:20 PM
D Hanson's Avatar
MB Quarts are okay if you go with the QSDs, but you can get comparable for less. The CDT Hign definitions are are about $ 400.00 and they sound just as good. If go with lower priced MB Quart like Premium or Reference series, make sure you attenuate your tweeter by about 4 to 6 dbs or the tweeter will sound harsh.
http://www.woofersetc.com/product.asp?0=239&1=240&3=1171
The MB Quart Qs are very good to use in the back of a convertible though because they have speacers. I could not fit CDTs back there and CDT have a fairly shallow, but wide basket.
I do love the MB Quart QM 25 tweeters though. They cannot be bought in a component set and they are very large (about 1.5 inches).
03 996 TT Blk/Blk
Old 01-12-2004, 08:28 PM
techweenie's Avatar
D Hanson: Thanks!
I'm a big fan of Dynaudio & Vifa as brands where you're paying for intrinsic, rather than extrinsic quality.
1969 coupe hot rod
Old 01-12-2004, 08:31 PM
Mr. Hanson, are you SURE you don't want to adopt?
My car is at one of the most fantastic audio shops in the area and I'm going to pick it up this weekend. I'll have plenty of pics to post!
Adam
1978 911SC 3.0 (former)
a_roseneck@hotmail.com
Old 01-12-2004, 08:39 PM
mjshira's Avatar
D Hanson & others
thanks!
I have a nak 400 deck and will probably run three way fronts with a small sub. I am no way as picky as Hanson so I think that I'll just take his advice on a mid range system and be done with it!
D Hanson, look for a PM from me
THanks !
Old 01-13-2004, 06:25 AM
techweenie's Avatar
mjshira, I'm thinking about the Nak 400, myself.
How is the FM section? I've heard it's not as good at receiving FM as other, comparably-priced head units...
1969 coupe hot rod
Old 01-13-2004, 07:44 AM
mjshira's Avatar
I don't have it hooked up for radio and in fact plan to run SAT so I wouldn't know. It is a great stereo. I don't like the other units that have 20 different colors and switches etc, this is old school kick ass stereo
Old 01-13-2004, 09:41 AM
