I'm just curious if we use less timing and cheaper fuel, how will the cars perform? I for one have gotten better mileage out of lower octane fuel. Is it due to the higher energy levels? Sprint. |
An interesting thing ive seen done is the placement of a rheostat in place of the O2 sensor, allowing you to tweak the parameters of your A/F ratio (to a limited extent depending on your DME)
Not sure of the exact model # but i know that both MSD and Jacobs Ign. make a spark unit that allows for knock sensor (piezo electric crystal) input to advance/retard timing. You retain your distributor but have to tack weld your advance weights in the non advance position. Pretty much a replacement for the origional CD Ign. O ya... Im jelous of you mid west or eastern guys and your 93 octane available at every pump. We've got sunshine here in CA but crap for gas!!! I never go to Arco!!! too many bad experiences there.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
May I ask for people's experiences with the aftermarket knock control devices like the J&S Safeguard http://www.jandssafeguard.com/ device mentioned earlier in this thread?
I recall one 930 owner saying he had one and it worked well - this was in a thread several months ago. I've also read opinions that external knock sensors don't work well on air-cooled 911 motors, but the factory uses one on the 964 engine. Surely the race engine gurus here must have had some experience with these devices? What I am especially wondering about is if the J&S device operates independently of whatever engine management system you have, so you could piggy-back it on top of a Motronic. Edit: Sorry, I did find these reviews on the web: http://www.hughesengines.com/features/product_of_the_month/sept_03.asp http://www.mustangworks.com/articles/poweradders/KnockControl.html And I found this install guide, not for a 911 but it sounds pretty darn simple anyway. http://www.scoobymods.com/forums/showthread/t-289.html
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . he and him? Last edited by jyl; 01-15-2004 at 09:39 AM.. |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Let's do an analogy. Suppose your trying to push a car along a street. You would get right behind the car on the street and start pushing. This would give you maximum leverage and force. But suppose now, you move off to one corner of the car, so you're pushing at an angle. Even if you use someone much stronger, they are still at a disadvantage because they are not in the optimum location for pushing the car. In your engine, it's somewhat similar. You want maximum pressure in your combustion chamber *just after* the piston has reached Top Dead Center (TDC). Since fuel takes time to burn, you want to ignite the mixture before TDC to give pressures time to build up in the chamber (pressure resulting from the explosion of the gas/air mixture). Having your pressure at a maximum right when the piston is in the right spot is important to maximizing power. If your mixture ignites prematurely, then the pressures may build up on the piston before it reaches TDC, and it may try to push it in the opposite direction. This is bad, and this is what is called pinging. Now, back to octane (and again, this is off the top of my head). The slower burning fuels allow pressure to build up slower and combust slower. So instead of having a big POP at near TDC, you have combustion that takes place over a longer period of time, while the piston is traveling back to the center of the engine. This gives more power because the pressure is uniform along a larger portion of the stroke. Diesel engines have very slow burns like these, so that is why they have a lot more torque (they have more uniform pressures along the length of the stroke. On a side note, maximum leverage for the piston is when the rod is at a 90 degree angle with the crank. You would think that this is when you want maximum pressure in the combustion chamber, but I don't think it works out quite that way all the time. -Wayne
Navin Johnson
I dont have hands on experience with the J&S unit but am familiar with someone that has it on a highly modifed 930. The car has Haltech E6K engine management and waste spark ignition.
The J&S intercepts the signal from the ecu to the coils, if no knock is present, no adjustment is made. If knock is detected, the timing is adjusted. I thinks that saying air cooled engines are noisier than water cooled engine is an old wives tale. Both air cooled and water cooled engines share the same components, i.e. cams, chains, rockers, pushrods, pistons, valves, crankshafts, etc. The water jacket really prevents us from hearing all the noises that exist in an operating engine, but internally the noise still exists. In an air cooled engine no water jacket, and hence a seemingly "noisier" engine. Ever listen to an engine with a stethoscope or end of a screwdriver while trying to diagnose something? You hear a nice rythmic cadence whether its a air or water colled engine. FWIW Im using Bosch donut type knock sensors on one of my engines. The EFI that I chose has 2 channel knock control. However I wont be able to get any dyno time until this permafrost recedes. ![]() ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I called J&S Safeguard and spoke to the guy briefly. He said their "Universal" units works on a '80s Porsche w/ stock Motronic.
The universal unit is pictured at: http://www.jandssafeguard.com/images/UniversalApp.jpg And installation instructions are here: http://www.jandssafeguard.com/UniInstall.html He said one location for the knock sensor is under the fuel rail. The Universal unit comes with a GM knock sensor for $495, a Bosch knock sensor costs an additional $50. I don't have any personal experience with this device - all I'm doing is searching and reading on the web - but it looks really interesting.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . he and him? |
Wayne is correct about cylinder pressure and when the optimum ignition
should occur. Check out the Graphs page at this URL (www.systemsc.com). I've plotted some graphs at the bottom which provide further insights into what Wayne has discussed.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
I have a couple of questions for LorenfB and Wayne at pelican Parts. Before I ask I'm not trying to turn this into the usual LorenfB Vs Steve Wong pissing match, I'm just looking for some insight.
Here goes. Loren, Do you some specific issues with Steve, Steve's product, the way Steve does business or chips in general. The underlying theme of the majority of your threads gives me this impression. Wayne, "That said, SteveW's chips seem to get high marks from satisfied customers - we will be carrying them in the catalog in the very near future. For the price, a chip replacement is still one of the best ways to increase off of the line performance. BUT, you're running your engine closer to the edge, which will cause increased wear and possible damage" Wayne, are SW's chips being carried in the catalog based solely on customer demand or on the merits of the product. It seems an unlikely association given all the controversy associated with this particular performance chip. I think everybody or almost everybody on the board understands that increasing the output of the engine may result in a potential decrease in service life. That said, every after market component (sport muffler, cat-bypass, free flow air filter, etc) should be considered suspect as it alters the operating parameters established by the manufacturer.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
As for LorenB's comments and concerns with Steve's chips, I think this was discussed to death in a previous thread - please search the archives. -Wayne
Thread Tools | |
Rate This Thread | |
