Senior Member
Setting Points Gap
Am I the only one who pulls the dist when setting points gap? I set the motor to the No. 1 cylinder then pop the rotor and dist and set them on the bench, and then re-check once in in the car. Then set timing, check dwell etc... Might take a bit more time, but I get into a routine and it seems to work better for me.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 01-17-2004, 09:58 AM
Bill Verburg's Avatar
That's the way I always did it. I can't imagine doing it in the car, must be a royal PIA
Bill Verburg
Old 01-17-2004, 10:02 AM
Super royal PITA - I used to always pull it, until I went to a Pertronix.
Old 01-17-2004, 10:05 AM
Senior Member
I have thought several times about going to Pertronix. I guess I am a masochist, there's something Zen about having to chase my arse around for a time tweaking and adjusting - but makes the tuning effort a sweet reward when its spot on.
Chris
Old 01-17-2004, 10:16 AM
Early_S_Man's Avatar
Porsche Crest
Chris,
I ALWAYS pull it out, because that gives you a chance to pull the point plate and cam, and clean up the centrifugal advance parts ... so you can lube and head off any future 'sticking' problems! Been doing that since 1969 when I installed a Bosch '010' distributor in my hotrod Beetle.
If you do the Pertronix 'thing' ... your centrifugal advance mechanism will get NEGLECTED! And, it won't like that treatment, so it will reward you with a sudden case of 'off-color' running, out in the boonies where you won't be prepared to fix the problem!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-17-2004, 11:00 AM
