LinkBack Thread Tools Rating: Thread Rating: 8 votes, 4.50 average.
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
bumper pads...remove them?
I am thinking about taking them off, but the appearance of the bumper is in question. I have taken one off to see the color under them and it's bright compaired to the faded UV exposed area. Since I am going to be replacing the F/R fender soon and having it painted, my thought was to have the rear bumper painted then as well and never put the pads back on.
What do you think?
Here is a photo I edited to get an idea.
With pads:
And no pads:
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-19-2004, 01:27 AM
thrown_hammer's Avatar
I would remove the rubber strips as well and have all the holes welded shut and ground smooth. Then repainted.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 01-19-2004, 05:03 AM
It looks good. If you can discretely place the lights somewhere and finish the bumper so there are no bolt holes showing it is a cleaner look for sure.
Taking all that weight off the back, you may have to re lower the rear end. And where will you sit when your behind your car chatting with someone? They ARE perfect seats you know!
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 01-19-2004, 05:04 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Here's the latest thread that I know of on removing the pads
show me rear bumper pad removed on a 78-89
Here's what my car looked like before installing the caps
Although the bumper was painted after removing the pads, so a bumper that has its original finish is most likely going to have discoloration and blemishes like rubber residue and aluminum corrosion.
Kevin L
'86 Carrera "Larry"
Old 01-19-2004, 05:26 AM
Montana 911
k9handler's Avatar
I am going to go with pads removed, and I am thinking of the trim removed as well. I guess I can alter the image further to get that look for a test look.
H.D. Smith
2020 Yamaha YFZ450R
Old 01-19-2004, 06:29 AM
Montana 911
k9handler's Avatar
ok, no trim...I like the look.
H.D. Smith
2020 Yamaha YFZ450R
Old 01-19-2004, 06:37 AM
TargaRob's Avatar
If you like it, do it. It takes somewhere around 18lbs. off of your bumper.
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 01-19-2004, 08:24 AM
All I know is I was happy to have them when the ******* behind me forgot to use his brakes. Much, much less expensive to have had them to cushion the blow.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 01-19-2004, 08:39 AM
This looks great Smitty ! Remove all the rubbers i say
87 Carrera Backdate
Old 01-19-2004, 08:42 AM
TargaRob's Avatar
That's very true, Jgordon. The reasons I have mine on:
1. Add extra protection
2. Keeps the SC/Carrera look
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 01-19-2004, 08:44 AM
Friend of Warren
Smitty your photoshop skills are good, but you forget to take into account the bumper shock studs as shown in this picture from another thread:
Kurt V
Old 01-19-2004, 08:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The reasons I have mine off:
1. If someone hits me, the likelihood of those things reducing the damage is small. Parking lot tap is the only situation where I can think of them helping to avoid any significant damage. I park in the farthest reaches of any p-lot, so..........
I know another member of the board said the pads saved him from impending damage when he spun during spirited driving on a slick, pine needle covered road, but I think the man upstairs had more to do with it than the big black pillows.
2. If someone really hits me, the car's gonna be messed up pretty good anyway. I won't be crestfallen when the bumper pads are destroyed in the wreckage. The other body damage (which the pads would not have prevented) is a different story
3. These aluminum bumpers are a dime a dozen from other board members or dismantlers, so replacing the bumper itself in the event of a cruncher won't cost much at all.
4. Those bumper pads look like sheet.
I'm not trying to be a jag about this. Just having some fun with the discussion.
Seriously though, look at the pre-74 cars, the Euro 74-89 cars, and the post-89 cars. All of the aforementioned cars have much smaller or non-existant bumper pads. I just think the US DOT pads are overkill and obnoxiously big, heavy and unattractive afterthoughts.
Kevin L
'86 Carrera "Larry"
Old 01-19-2004, 09:11 AM
Montana 911
k9handler's Avatar
Thanks Kurt...had no idea them studs were under the trim. My first thouight was two small reflectors to cover them as the RS had (I think) and it would look ok.
H.D. Smith
2020 Yamaha YFZ450R
Old 01-19-2004, 09:57 AM
Montana 911
k9handler's Avatar
change #3
H.D. Smith
2020 Yamaha YFZ450R
Old 01-19-2004, 10:02 AM
Binge User
Schrup's Avatar
I will soon be removing mine till I get a couple of Ruf bumpers next year. I got this idea from an earlier post, these light bolts may keep things legal for me. I'll put them in the top mounting holes.
http://www.stylinconcepts.com/part.cfm?PartID=409968&PartFamilyID=583&SubCategoryID=316&CategoryID=25
Paul
Old 01-19-2004, 12:00 PM
Someone said weld the holes. Not sure how you would weld... since bumper is aluminum.
Just a thought.
Jim
Old 01-19-2004, 12:07 PM
Senior Member
Superman's Avatar
Yep, aluminum can be welded. I wonder what those bumpers would look like stripped and polished. For that matter, I wonder what Bailey would look like in the same condition. Photoshop anyone?
Mocha 1978 911SC. "Coco"
Old 01-19-2004, 01:08 PM
after reading this forum, I went out and weight the bumper pad and WOW! It is a brick. I could not believe how heavy they were. Needless to say the bumper pads are not going back on. But I am keeping the rubber strip for cosmetics.
74 911S 3.2 GTS
74 914-6
Old 01-19-2004, 01:21 PM
Get the Euro smaller rubber.
Old 01-19-2004, 01:29 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep. About 7-8 lbs they weigh (each).
Kevin L
'86 Carrera "Larry"
Old 01-19-2004, 01:33 PM
