RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
Show me your rockers
I bought a set of steal SC flares from Brad at BW Motorsports when I ordered my RUF Yellow Bird bumpers. He cut them off a wrecked car.
He called tonight and needed to know if I was going to use the C2 rockers (if not he was going to weld up the holes on the flares for the bolt hole of a C2 rocker). I haven't gave it much thought until now. I know some people run with out them. Can someone post some pics of a C2 rocker and any other choices out there for my application.
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 01-09-2004, 02:37 PM
964 rockers aka C2
regular rockers
no rockers
Old 01-09-2004, 03:17 PM
jyl jyl is online now
jyl's Avatar
My vote - no rockers! Such a clean look.
Old 01-09-2004, 06:54 PM
exc911ence's Avatar
Can you remove the rockers off of a 74-up car? What's underneath?
1979 911SC "Frankencab"
Dave
Old 01-09-2004, 08:03 PM
I bunch of ugly screw holes and supports along with exposed oil and air conditioner lines. Not that is can't be done. It 's just that your going to need to do some patching and minor body work to make it look good.
Old 01-09-2004, 08:30 PM
Porsche's Avatar
Mmm... no rockers do look good... that's something to consider...
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 01-09-2004, 11:25 PM
dickster's Avatar
no rockers on an '86
Rich
'86 coupe
"there you are"
Old 01-10-2004, 01:51 AM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-10-2004, 03:42 AM
dickster's Avatar
thanks ronin.
Rich
'86 coupe
"there you are"
Old 01-10-2004, 04:24 AM
Noel's Avatar
After just having my rockers off for torsion bar installation, I agree with 89911 that unless you do it right and patch all of the holes, it just doesn't look good. I vote for leaving them on.
Noel
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-10-2004, 05:13 AM
Larry Harris's Avatar
If you remove them you gotta patch the holes and do the bodywork, and then respray.IMHO
LArry
2001 Turbo
Old 01-10-2004, 05:30 AM
kellzey's Avatar
Qarl
Old 01-10-2004, 05:44 AM
Did you get the memo?
onewhippedpuppy's Avatar
Originally posted by kellzey
HA! But what's it look like rocker-less?
‘07 Mazda RX8-8
Old 01-10-2004, 06:47 AM
jyl's Avatar
Many good pics of rocker-less Porsches here: Like Carrera Sans Rocker Panels?
Old 01-10-2004, 07:09 AM
RickKlem's Avatar
Thanks everyone for the pictures and the input .
I think I like the look of the C2 rockers ,with the new yellow bird bumpers that I'm installing on my car.
So the next question would be, Does the C2 rockers just bolt right up to the old mounting brackets and predrilled holes on my "S" car (rocker area)? It will have "SC" rear fenders welded on by then and front and rear Yellow Bird bumpers installed.
Has anyone did this install on there 77 S.
Thanks again
Rick
Old 01-10-2004, 09:53 AM
ipapilot's Avatar
Rick, you will need to talk to Brad about how his rocker panels mount. I don't think you will be using any of the same holes, and will most likely be using some 3M double sided tape in additon to a couple screws on each side.
PS. Try and make it to the Chili Cookoff next Saturday in Montgomery if you can. Details are on the Ala Pca website...
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 01-10-2004, 10:07 AM
19 years and 17k posts...
azasadny's Avatar
Here are "rockers"!
Rockers!!!!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 01-10-2004, 02:01 PM
Gon fix it with me hammer
svandamme's Avatar
thx for that, i'll have nightmares again
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-10-2004, 02:04 PM
I did a search on 964 rockers and found some very good information on what it would take to install them here: Factory C2 conversion?
I'm thinking of doing the same too if I can find the parts for reasonable $.
Cheers,
Joe
Old 01-10-2004, 02:44 PM
Yellowbird RS's Avatar
try this
try better boddies rocker side SKN
X/A
Old 01-19-2004, 12:48 PM
