BURN-BROS's Avatar
A turbo conversion 6 is just a little more than a 3.6 conversion if you can do all the fab work. Ask me how I know.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-23-2004, 12:34 PM
iamchappy's Avatar
Yes but my car will still perform like it should before the turbo kicks in, so the slowest my car will ever be is a 914 with a 3.0 SC CIS engine in it which has got to be a little bit faster than a 911SC which is fast enough for most. The turbo comes on at 3,500 which is also sooner than my present power band.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 01-23-2004, 02:02 PM
iamchappy's Avatar
Are you saying that it cost you more than a 3.6 engine to add a used bae turbo kit that can be picked up for around 1,500 bucks plus the fabrication of a few pipes. I am only looking to run at 8-9lbs. rfng has been working up a new kit for around 4,000. I do not believe that I could sell my engine and replace it with a 3.6 plus clutch and tranny for less than that.
87 924S
Lexus SC400
Lexus LS400
Old 01-23-2004, 02:09 PM
BURN-BROS's Avatar
No, I had conversion vs conversion in mind. If you take a 3.6 conversion budget and a 3.3 turbo conversion budget they are close to one another.(so far) I did not have the turbo kit in mind.
Burnham Performance
Old 01-23-2004, 02:45 PM
