A turbo conversion 6 is just a little more than a 3.6 conversion if you can do all the fab work. Ask me how I know.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Yes but my car will still perform like it should before the turbo kicks in, so the slowest my car will ever be is a 914 with a 3.0 SC CIS engine in it which has got to be a little bit faster than a 911SC which is fast enough for most. The turbo comes on at 3,500 which is also sooner than my present power band.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Are you saying that it cost you more than a 3.6 engine to add a used bae turbo kit that can be picked up for around 1,500 bucks plus the fabrication of a few pipes. I am only looking to run at 8-9lbs. rfng has been working up a new kit for around 4,000. I do not believe that I could sell my engine and replace it with a 3.6 plus clutch and tranny for less than that.
No, I had conversion vs conversion in mind. If you take a 3.6 conversion budget and a 3.3 turbo conversion budget they are close to one another.(so far) I did not have the turbo kit in mind.
