Tach problem help requested on 86 Carrera
Hi All,
I know this has been discussed before, however I'm looking for a bit of advice-
Car: 86 3.2 Carrera Coupe
Issue: Tach will be reading perfect, then suddenly drop to zero. Stay there for a while then jump right back and work perfectly. This comes and goes. It will work fine for 30 min. or 2 hrs., then drop to zero for 2-3 min. then jump back and read perfect again. It has been doing this for about 2 years now and is driving me crazy. (It does not fly around erratically, either perfect or zero.)
I crawled under the car to check the ground strap on the tranny and it does seem secure and realatively clean (I had the tranny out a year ago so I assumed the wrench cleaned the connections but maybe not). I did notice a spot on the strap that seemed to be wearing a bit, but everything appeared solid.
I R/R the alternator/voltage reg about 3 months ago and it is working perfectly.
What should I do next?
I understand the tach receives it's juice from the DME (?). Are there connections I should check/clean? Should I check the connection at the Tach itself. Should I remove the Tach and send it to be repaired? Should I remove the tach, use a volt meter while driving to see if I'm getting a constent volt feed?
I spoke with one wrench to said it was probably the Tach itself, but why would that be the case if it works perfect 80% of the time.
Does anyone have a check process or series of checks to go through prior to sending the Tach off for evaluation/repair?
Thanks much for any and all help!
Regards,
Jim
'86 911 Carrera
'88 528e
Old 01-22-2004, 12:50 PM
Pull the tach out and check the connections on the back. You should also check the connections at the DME under the drivers seat.
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 01-22-2004, 01:02 PM
