RETIRED
Joe Bob's Avatar
2.4 and 2.7 engines, both need rebuild, what can I do?
OK....looks as if the 2.7 powered 914 is history....got a buyer in Illinois and a wire transfer coming in....got full price at 16K....well worth it....so....the next project is a 74 stripped racer with a C2 body kit....
I have a carbed 2.4 with a rod knock, Weber carbs, and disassembled 2.7 with all the tin exhaust and whatever......
What mods can I do on the 2,7 case to make a screamer? Obvioulsy cams with pistons and cylinders need to be purchased....the deal has a rebuild kit......any suggestions?
2012 ML350 3.0 Turbo Diesel
Old 01-26-2004, 07:19 AM
I've got some S cams and a full set of twin plug heads that are available if you need them for this project.
Old 01-26-2004, 07:30 AM
RETIRED
Joe Bob's Avatar
I will keep you in mind....send me an email with prices and what mods need to be done. What dizzy do you use for the dual plugs?
356@cox.net
Old 01-26-2004, 07:32 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
10.5:1 compression with twin plugs and S cams will go a long way towards making a screemer. Does the 2.7 have nikasil cylinders?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-26-2004, 07:51 AM
dtw dtw is offline
GAFB
...and I've got a set of 40mm ported heads and a twin plug dist. (964). You'd have to enlarge the mating surface of the heads (they're 2.4) and drill and tap them for twin plugs. But the expensive stuff's already done. I was strongly considering doing an 10 or 11:1 twin plug 2.7 screamer myself...
Several BMWs
Old 01-26-2004, 08:38 AM
Early_S_Man's Avatar
Porsche Crest
2.7 cylinders slip right into stock 2.4 heads without ANY MACHINING!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-26-2004, 08:57 AM
dtw dtw is offline
GAFB
There ya go. Bonus!
Several BMWs
Old 01-26-2004, 09:07 AM
