Its time to have the broken head stud fixed. Not because the cylinder is leaking but because everything else with a seal is leaking. Its leaking so much oil the car looks like its on fire when I stop at a light. Everything seems to have started leaking when I switched to Mobil One. Maybe that was a mistake. Maybe it was not driving it everyday anymore.
So I went to my favorite garage today to discuss the leaks. Besides the headstud issue the cam seals are leaking big time. He quoted me about $1,000 to replace the cam seals and oil return tubes which are probably the cause of all the smoke since the oil drips onto the heat exchangers. His recommendation is to take the motor down and replace the headstuds, all the seals, oil return tubes, do the valves and check everything else. He estimates that should run about $2,800. He's leaving the bottom end up to me to decide. Question is what do others that have gone through this think. We also discussed performance upgrades. His recommendations were cams and headers since I have a mass flow sensor. Headers would require me to move since Houston has a new standard for the emission test. Or I could spend big bucks to get an exhaust system that does have cats. Help.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Many have stated here that the bottom end is good for 250,000 miles. Or more. Many have also stated that by the time you get the heads off to do the valves, it's not that much more work to just open it up and install new bearings, bigger oil pump, yada, yada.
I don't mean it's not much more money. It seems to be a LOT more money. Go back to dino oil for the time being. You might find that your oil leaks will subside enough to just do the oil return tubes, cam seals and some other superficial stuff. |
Usually if the head stud is pulled then you need to insert case savers into the case. That means that the bottom end must be rebuilt. $2,800 is a very cheap price for the entire rebuild. I'm doing mine myself and it's costing me about $3k. I think mechanics quote something like that and then run over budget or cut corners. Believe me it's an expensive thing to do and there are many parts to buy.
B.T.W. You don't really need a new oil pump if you have a '76 and later pump in good shape. If you track the car then it'd be a good idea to modify the oil tank to install a baffle so that you don't lose oil pressure under braking. Good luck Tristan |
aluminum case engines break studs, they don't pull out. what's the mileage? a complete valve grind with all new parts would go for about $3500 in these parts. add another $1000 for 12 lower studs, rings, rod bearings and rod bolts. the oil pump should be fine.
John
You're right of course. I didn't read correctly. Thought he had a mag case. ![]() Tristan |
Might as well do the whole thing. Top and Bottom.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
You might want to read my story at the link below . . .
On the Mobil 1 business - My car leaked like a sieve with synthetic oil. I switched back to dino and it's tight. I don't know why some people can use synthetic oil and others not. It may be the year of my car: 82.
- Bill
1982 Porsche 911SC Coupe 1999 Porsche 911/996 Coupe |
