how to make a 2.7 to a 3.0 cheaper than 3000
i have a 2.7 & im wanting to make it bigger with out spending 3000.? does anybody have any good suggestions.any info would be very helpful.thanks jim
Old 01-29-2004, 02:12 AM
Licensed User
Shuie's Avatar
swap it for running 3.0 and sell your core. Look for a motor that has already been upgraded and documented. Rebuilding a 2.7 into anything bigger is going to be tough for under $3k. Good luck!
Old 01-29-2004, 03:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Steal a SC..............
Or get one for a steal. Agreed that building the 2.7 is not the way to go. Find a good deal on a 3.0L and do a swap. Hopefully your core will be a solid one and help you recover some of the cost. A refreshed 3.0 is going to be hard to get a good deal on. The ones that are a little tired are those that can obviously be had cheaper.
Kevin L
'86 Carrera "Larry"
Old 01-29-2004, 07:19 AM
yes but let me explain i have a perfect 7r case that has alot off nice machine work done by olies this case has never pulled a head stud,i have a realy nice set of rsr spec heads(small stud spacing) 964 pump s rods olies did all machine work ive got to much in it to throw away im looking on a deal on pistons and cylinders?
Old 01-29-2004, 08:44 AM
Early_S_Man's Avatar
Porsche Crest
Jim,
Andial 2.9 conversion set is around $5 less than $3K ...
EBS might be able to supply some reconditioned 3.0 cylinders and JE 9.5:1 pistons for a little less ...
Those are about the only real option, unless you expect a windfall estate auction, or something of the like!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-29-2004, 08:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Oh. Well that makes a big difference! Gotta tell us that up front.
Kevin L
'86 Carrera "Larry"
Old 01-29-2004, 09:11 AM
Licensed User
Shuie's Avatar
sorry about that, I thought your 2.7 was a used up core.
For $3k, maybe custom J&Es and cams. What induction are you using?
Old 01-29-2004, 09:22 AM
mfi manifolds with 40 pound msd inj. and a tech unit from electromotive,intercooler on top like 934,twin 996 turbo's with 1&5/8 headers.
Old 01-29-2004, 07:45 PM
PRO Motorsports
Tyson Schmidt's Avatar
Doesn't JE make their own 2.9 pistons and cylinders now for something like $1900? That's what I was told anyway.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-30-2004, 07:27 AM
that is the first i have heard that they make cylinders ill call today thanks ill give that a shot thats more in my range!
Old 01-30-2004, 08:45 AM
TerryBPP's Avatar
What kind of heads/headwork is need for the 2.9 conversion? Is twin plug necessary?
Old 01-30-2004, 08:49 AM
andial says its not a nesesity but im twin plugging mine cause of turbo.i guess it depends on combo and useage.
Old 01-30-2004, 06:26 PM
pjv911's Avatar
Send a message via AIM to pjv911
I guess this is always an option .
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33623&item=2456179208
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-30-2004, 06:58 PM
that is what i did not want to have to spend!
Old 01-30-2004, 08:33 PM
jase007's Avatar
birel23:
The Motor-M says $3k for the kit and the case needs to be open. Any idea what other mods they need to do? Open up the spigots? etc... have you heard / seen performance on this kit?
I ask b/c I have a "spare" '74 CIS 2.7 that I might upgrade.
Thanks.
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 01-30-2004, 09:12 PM
the kits i have seen have studs cylinders/pistons rings ect and all say machining case. i just want the cylinders,but i have not seen them sold seperately. i drove a car before and after the andial kit was installed. it much better torque.it felt like sc then. i am worried about the case getting to weak. i race mine. i have never had a problem with it yet. i have never even pulled a head stud & i run 1.2 bar of boost.my case has been align bored & has had oil update& dilivars upper and lower.all the kits i have seen are for non turbo applications that is why i just want cylinders & then ill have pistons made or find a set of good used ones.
Old 01-30-2004, 09:24 PM
The Chef
Guest
Posts: n/a
OH NO! NOT MOTOR MIESTER AGAIN! RUN FOR YOUR LIVES!
Old 01-31-2004, 12:07 AM
whats up with motor miester??
Old 01-31-2004, 01:19 AM
hugo454's Avatar
MOTORSHIESTER!
Old 01-31-2004, 04:32 AM
Ho Hum 74's Avatar
Did anyone find out if Tyson's post was correct? It's too early to call JE where I am.
I have a 2.7 7R case with 9.5:1 JEs and Mahle jugs and MFI. Engine is currently apart for re-build.
Do you guys think the 2.9 set from JE would work with my heads or am I going down the road of no return? I could sell my 2.7 JEs and jugs. Upgrade would be around $900.
Oh. Almost forgot. I thought Bruce Anderson said that the wall thickness of the 2.9 cylinders was too thin. Are these custom cylinders???
Cheers,
Tristan
Old 01-31-2004, 05:23 AM
