nkader's Avatar
Exclamation Turn signal stopped blinking
Yesterday I noticed that my turn signal stopped blinking on the dashboard. I parked the car and checked to see if it was blinking outside the car and it was not, just a solid yellow light on either side.
What do I need to do to get it blinking again?
The car is a 1969 911 T.
Thanks for your help,
-Nino
Old 07-12-2004, 09:56 AM
steve911's Avatar
Nino--
I'm going to guess that a relay has gone bad, but the electrical gurus here will surely be able to tell you more definitively.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 07-12-2004, 10:05 AM
nkader's Avatar
Does anyone know where the turn signal relay is located?
Old 07-12-2004, 01:25 PM
JTO JTO is offline
I had a problem like this and found that the bulb was faulty; it made intermittent contact in the housing.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 07-12-2004, 01:27 PM
sithot's Avatar
Relay
Pull out your oil level/temp gauge. Use a flashlight. It's behind the gauge mounted just forward and down. It's black. If it cooked itself it will show signs of getting hot. They do wear out.
I don't have the part number but don't get an aftermarket one from Autozone or anywhere else. Use a Hella piece and it will work flawlessly. I've had experience with the ones from BAP/GEON and NAPA.
Good luck,
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 07-12-2004, 01:32 PM
ruf-porsche's Avatar
Bad flasher or bad bulb.
Old 07-12-2004, 02:18 PM
nkader's Avatar
It is a bad flasher. The bulbs all work just fine.
Old 07-12-2004, 03:33 PM
Send a message via AIM to fintstone
Lots of good troubleshooting links in the recent past for turn signal problems if you do a search. here are just a couple:
Turn signal relay in a 71?
Flashers = not | | Emergency = yes -> Whats up?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-12-2004, 09:02 PM
Automotive Monomaniac
Emission's Avatar
My first DIY replacement on my Porsche was the turn signal assembly...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 07-13-2004, 12:15 AM
