Yesterday I noticed that my turn signal stopped blinking on the dashboard. I parked the car and checked to see if it was blinking outside the car and it was not, just a solid yellow light on either side.
What do I need to do to get it blinking again? The car is a 1969 911 T. Thanks for your help, -Nino |
Nino--
I'm going to guess that a relay has gone bad, but the electrical gurus here will surely be able to tell you more definitively.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Does anyone know where the turn signal relay is located?
I had a problem like this and found that the bulb was faulty; it made intermittent contact in the housing.
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Relay
Pull out your oil level/temp gauge. Use a flashlight. It's behind the gauge mounted just forward and down. It's black. If it cooked itself it will show signs of getting hot. They do wear out.
I don't have the part number but don't get an aftermarket one from Autozone or anywhere else. Use a Hella piece and it will work flawlessly. I've had experience with the ones from BAP/GEON and NAPA. Good luck, Tom
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
Bad flasher or bad bulb.
It is a bad flasher. The bulbs all work just fine.
Lots of good troubleshooting links in the recent past for turn signal problems if you do a search. here are just a couple:
Turn signal relay in a 71? Flashers = not | | Emergency = yes -> Whats up?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Automotive Monomaniac
My first DIY replacement on my Porsche was the turn signal assembly...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
