McG McG is offline
2 things- 915 rebuild or rebuilt?...does this list sum it up?
Car: 1984 Targa, daily driver with 139000 miles, not a track car...canyon car.
Problem: Transmission Toast
Ive read through 915 rebuild posts for a couple days and have a couple questions.
1. Why would you rebuild "your" transmission as opposed to swapping it with an already rebuilt trans...the shop has the rebuilt one already (the rebuilt was built at the same shop my car is currently at...quality So. Cal. shop) ? The savings is approx. $600 for the rebuilt and my old one.
2. Listing of parts going in "my" trans...any additions?...are we missing anything easy to replace "while in there" considering this is my baby...but gritting my teeth already at the cost...gulp!!!
915
gasket set
synchro - 1st gear - n
synchro - 2nd gear - n
dogteeth 1st - n
dogteeth 2nd - n
dogteeth 3/4/5 -n
slider 1/2-n
slider 3/4 -n
shaft nuts
syncro 3/4//5 -n
Locking bands
swepco
Clutch
(machined flywheel)
Clutch pack
pressure plate bolt
flywheel seal
flywheel bolt
pilot bearing
Misc.
breather hoses
red oil switch
thermostat o ring
oil/filter
Thank You all...And may you squeeze a few more miles outta that transmission, cause this hurts!
McGeorge
Old 01-30-2004, 03:41 PM
scottb's Avatar
As with any rebuilt or overhauled product, you don't really know what you're getting unless you see the process. The shop might only replace parts that are "out of spec," and leave parts that are worn but still servicable. It seems to me that by doing the job yourself, you ensure that everything that needs replacing is replaced, and that you do all of the little extra "while you're in theres" as well. If I'm ever in your shoes, and I have the time, I'll probably rebuild mine myself.
1984 Targa
Old 01-30-2004, 03:58 PM
McG McG is offline
Oh, and to clarify, I wont rebuild it myself...I will have the shop rebuilt it. I poke around a little bit, but I'm not on the DYI level that most of you guys are. Thanks Again.
McGeorge
'84 - 911 Targa
Old 01-30-2004, 04:07 PM
