play in shift coupler
I bought what is claimed to be a new shift coupler (on eBay).
It has about a mm of axial play in it -- I can push or pull on it about that much -- maybe a bit less. There is no rotational play, and the part of the plastic bearings I can see from the side are gray. Do I have a problem? And does the bearing description make sense for a new unit? Thanks! |
I think OEM bushings are supposed to have play like that? The Pelican ones are much tighter.
ditto what ubiquity0 said.
83 SC (gone) // 72 T (gone) |
Irrationally exuberant
The 911 ones are oval but I hear 914 ones are round.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I recently purchased a new shift coupler from Pelican and was
surprised at the amount of play in it. From what I've heard, if you buy just replacement bushings, (they're different?) they are supposed to fit tighter into the coupler.
Kurt |
Randy,
The O.E. coupler design must have some axial play to allow for some freedom of misalignment in the horizontal plane (as installed in the car). Otherwise, if the shifter were not exactly in line with the shift rod from the transmission, the coupler bushings, shift rod and shift tube would have to distort to align the parts. Regards Hayden |
"misalignment in the horizontal plane"
Eh?? To me axial play means along the axis of the shift lever. It has no play horizontally, if you mean to the left or right when installed. The only pay would be front to back as installed. Is that what it should have? |
OEM has play to eliminate vibration from engine/transaxle.
Replacements do not. |
Randy,
If you place the coupler on the bench, view from above as installed in the car, you will see you can deflect the knurled stump to the left or right (freedom in the horizontal plane), this is a function of the slotted holes and the small clearance between the inner sides of the bushes and the knurled stump. At maximum deflection left or right, you will notice that one end of the cross pin is at the forwards end of the slot and the other end is at the opposing end of the slot. The slot also allows for some vibration isolation, but not very efficiently. Subsequently the G50 shift mechanism deals with NVH in a more deliberate manner. Regards Hayden |
OEM has oval holes...for the reasons stated. Many have had good luck with round holes nonetheless.
--Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
The Stomski coupler uses an aircraft grade universal joint to handle the misalignment without introducing play. It might be the best little upgrade to the 915 shifter around. Really tightens up the shift pattern without introducing any negative characteristics. I really like it.
No association yada yada. YMMV.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
Binge User
I was hugely disapointed with the OEM coupler when I tried to install the new bushings & it broke so easily. I wasn't about to waste $80 on a new one. It was worth the extra $120 to upgrade to the Wevo unit.
Paul |
Thanks folks.
Does the Stomski allow enough movement for a street car? I seem to recall a post some time ago that the aftermarket couplers were too rigid for street cars with regular rubber engine/trans. mounts...? I only "wasted" $25 on this one so I'm not too concerned. This little sucker is heavy tho -- 1/2 lb. |
I have the Stomski on my street car and at the time it was a great addition-still is!. I have sport mounts.
The stomski is great little piece of engineering, so is the wevo. I find it much easier to adjust then stock. The stock one just feels sloppy.
72 911 Although it is done at the moment, it will never be finished. |
OK...I've posted this before....no real answers...
I've found out that the excellent Stomski coupling ( @ $192) is actually a part you can buy from Aircraft Spruce and supply for about $60 or so ....but with a collar added. Can anyone give us dimensions / details of the collar and setscrew, so we can fab this little bit of extra ourselves?? ---Wil Ferch
It's amazing how this stuff recurs every few months. One of the previous threads on this topic
