Senior Member
Superman's Avatar
Drag Numbers
I made the mistake of thinking yesterday afternoon and it wasn't long before I realized my mistake and quit, but not before I wondered:
Is there a figure (pounds, foot-pounds, whatever) that represents the wind force acting against a vehicle's forward motion at a particular speed? And are these numbers linear when force is plotted against speed? And how do they change from slippery cars like ours, to Mack trucks?
It takes force to accelerate a vehicle, but the force necessary to overcome the vehicles existing inertia is not what I'm thinking about. Once a vehicle is moving slowly at a constant speed of, say, two mph, the "maintenance" power needed has to fight only a teeny tiny bit of wind, and some wheel bearing resistance (minor). At a hundred mph, wheel bearing resistance is increased but still not great...and wind speed is much more ferocious. In fact, a few dozen MPH over that and wind resistance is about all a powerful engine can handle. So, we must be talking about quite a lot of resistance. How much? Where are these numbers?
I hope to get a grip on this "thinking" problem I have from time to time.
Mocha 1978 911SC. "Coco"
Old 02-06-2004, 05:58 AM
it's not linear it's more like an exponential ratio. I believe it is something like (not exactly, but very simplified)
Cd*f a*v^2
I'm not sure of the exact equation, but the important factors are
Coefficient of Drag
Frontal Area
and the speed
actually cars like ours aren't slippery at all
they are closer to mac trucks than say, a new audi. The bellows bumpers cars have a Cd of well over .4 while many new cars are closer to the low to mid .3's. The reason our cars do so well is that they have a relatively tiny frontal area. That's why Ruf did so much aero work when he did the yellowbird. When they changed to the 964 I think the Cd went down to the low to mid .3's.
Old 02-06-2004, 06:07 AM
Hey, here's tons more info for you
http://www.centennialofflight.gov/essay/Theories_of_Flight/coefficients/TH12.htm
Drag = Cd*1/2*rho*v^2*s
rho is the density of the fluid
s is the frontal area
v is velocity
Old 02-06-2004, 06:08 AM
djmcmath's Avatar
Note that if you want to calculate the force used to change speed, you have to integrate the above equation between the two speeds. Make sure your units are consistent, too -- if you use square meters for frontal area, use meters per second for velocity.
Oh, except the above equation isn't quite right. It's actually:
Fd = 1/2 * rho * Cd * Af * v^2
Fd -- Force of drag
rho -- density of the medium; IIRC 1.2kg/m^3 works for air at sea level
Cd -- drag coefficient. Masraum's got good numbers for those -- see Frere's book on the development history of the 911 for the exact numbers for any car.
Af -- frontal area -- should be a little less than 2 square meters.
V -- velocity.
I don't remember the exact numbers now, but because of that v^2 business, a little more speed hurts a lot more. Worse, after you integrate to find the force required to go from one speed to another, you get a v^3, so acceleration at higher speeds is more difficult by a function of the cube. Or more simply, the faster you go, the harder it is to go faster faster. Or for example, 60-90 might take you 4.2 seconds, but 90-120 is going to take a _whole_lot_longer_.
Does that help even a little bit?
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 02-06-2004, 06:21 AM
Not offended, but just out of curiousity what am I missing that is in your formula?
I also have
density -- rho
frontal area -- s
velocity -- v
Coef of drag -- Cd
Mine are in a different order, but since it's all multiplication that doesn't matter.
Old 02-06-2004, 06:28 AM
Senior Member
Superman's Avatar
You guys are making my head hurt. I'm not so smart as you think. How much force is acting on my car at 120 mph? How much is acting on the Peterbilt truck that's trying to pass me at that speed? How 'bout the Audi?
Old 02-06-2004, 06:32 AM
The problem is I don't have many of the numbers.
For bellows bumper 911 if I use 1 for the density, .45 for the Cd of 911, 120mph (53.67 m/s) for v, and 2 for frontal area I get
~1300 for a 911 (again, this number is pretty bogus since I fudged several things, but it should show you somewhat the relationship)
lets say audi, Cd.32, speed - same, frontal area 2.3
~1060
for mack truck Cd.65, speed same, frontal area 5
~4320
Again, I have no idea what the frontal area of any of these vehicles are, and I have no idea what the Cd of a mac truck is, and I just left out the density of air, but you should get a general picture.
So, our cars can hit the top speeds that they do based on the fact that they are small, and the engine and transmission were designed as a unit for going fast, not getting the best gas mileage.
New cars, Mercedes, audi, bmw, etc have better Cd in many cases, so they can more easily push through the air despite the fact that they are bigger cars.
If you want to make a 911 a top speed machine get a 964 or newer because you'll need much less power than in an older 911
same thing, but for 964, so Cd.32
~920 or 30% less power.
Old 02-06-2004, 06:51 AM
Hilbilly Deluxe
emcon5's Avatar
There used to be a web page with a database of Cd and frontal areas of common cars, with a calculator for determining how much power you would need to get to a given speed.
I thought it was on Mulsanne's corner, but I can't find it (lots of other cool stuff there though).
Anyone remember what the page was?
Tom
82 911SC Coupe
GTI Cup #43
Old 02-06-2004, 07:25 AM
Senior Member
Superman's Avatar
What units are those numbers expressed in? I understand the guesswork regarding the variables and that these numbers are not reliable or accurate. But what units is this hypothetical "1300" expressed in? Could this be expressed in something like "torque" numbers. Like lb/ft?
My engine makes somewhere around 200 lb/ft of torque, peak. So, if my car were geared high enough, I might reach a speed where the power generated by the engine exactly cancels out these various forces (wind resistance, bearing resistance and tire deflection). With this information, it would be possible to isolate these forces enough to estimate their values. From this, one could estimate the speeds at which they can outperform another specific vehicle, and at what speeds that other vehicle might be able to outperform us, heaven forbid.
Old 02-06-2004, 07:33 AM
well density is kg/m^3, v^2 would give m^2/s^2, and frontal area is m^2, so this would all cancel out to kg m/s^2 which I believe is Newtons or the metric equivalent of Force (lbs for us US guys)
So, where a jet engine is often rated for lbs of thrust you would also have to do the same thing for a car.
I'm not sure if hp has an easier or more direct route to pounds than torque does, but torque shouldn't be too far since you only have to get rid of one unit for them to be the same. ftlbs, if you can get rid of the "ft" then you are set.
Old 02-06-2004, 07:41 AM
MBruns for President
JeremyD's Avatar
Porsche Cd
924 - .31-.33
944T - .33-.34
911 Carrera -. 38-.39
911 Cabriolet - .40-.41
Boxster .31
Mercedes c class .27
Lexus LS430 .25
G-35 .26
Jeremy, for what years and with what aids, tails, etc...
Old 02-06-2004, 07:45 AM
Irrationally exuberant
ChrisBennet's Avatar
Now you see why billions a students rejoiced whenever the physics problem stated "Two bodies in a vacuum..."
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-06-2004, 07:49 AM
Bill Verburg's Avatar
Even things like ride height and a will affect Cd #s
Bill Verburg
Old 02-06-2004, 08:07 AM
JeremyD's Avatar
Here's a better list - with dates
Vehicle Year and Model Cd
'89 911 Cabriolet 0.32
'86 911 Carrera 0.32
'95 911 Carrera 0.33
'92 911 RS America 0.32
'90 911 Speedster 0.32
'94 911 Speedster 0.31
'80 911 SC 0.34
'80 924 0.35
'80 924 Turbo 0.35
'86 924 S 0.35
'80 928 0.34
'90 928 0.34
'93 928 GT 0.34
'93 928 GTS Automatic 0.34
'88 928 S4 0.34
'86 944 0.35
'89 944 0.35
'91 944 S2 0.33
'86 944 Turbo 0.33
'88 944 S 0.35
'90 959 0.32
'92 968 0.34
'92 968 Automatic 0.34
'90 Carrera 2 0.32
'91 Carrera 2 Tiptronic 0.32
'89 Carrera 4 0.32
'88 Turbo 0.37
'89 Turbo 0.37
'91 Turbo 0.36
'94 Turbo 3.6 0.35
'93 Turbo S2 0.36
Jeremy, where did you get those numbers. I don't have Frere's book in front of me, but they seem off from what I remember Porsche 911 Story publishing.
Not saying you're wrong, just that I could have sworn that the bellows bumper years were pretty bad, and that after that they improved by approx 33%.
Old 02-06-2004, 08:59 AM
JeremyD's Avatar
http://www.teknett.com/pwp/drmayf/porsche.htm
Old 02-06-2004, 09:11 AM
kjb kjb is offline
kjb's Avatar
remember that power = force * velocity, meaning that the power required to propel your car goes as the velocity to the power three.
This explains why my 70 hp Opel Kadett could get me going close to 100 mph back in the days. To make it go 200 mph, it would have needed roughly 70*2^3 = 560 hp. (It wasn't a very aerodynamic car.)
/ Johan
'86 coupe
Old 02-06-2004, 09:26 AM
banjomike's Avatar
Damn Jeremy, I just did the calculations with 0.38 for a carrera and you now tell me it is 0.32!?! @#$^#$ give me a second....
ok
Fd=0.5*Cd*A*rho*v^2
rho=1.225kg/m^3 at STP
Carrera
assumptions
Cd =0.32
Standard Pressure and Temp (STP)
A is approximated by a trapaziod 55" at base 50" at top and 50" tall
Fd @ 60mph = 66lbf (pounds force)
Fd @ 100mph=156lbf
Fd @ 150mph=315lbf
theoretical Mack Truck
Cd=0.8 (Mark's handbook for Mechanical Engineers)
A=6m^2
Fd @ 60mph = 959lbf
Fd @ 100mph= 2650lbf !!
Superman, the earlier statements are correct, drag force increases with the speed squared. power to overcome the drahg increases with the speed cubed!
drag due to rolling resistance increases linearly with speed.
here is a graph for a truck of the forces involved
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 02-06-2004, 09:30 AM
Jeremy, Interesting Find
Bill Verburg
Old 02-06-2004, 09:34 AM
