993 in the future - anything to beware of?
A few of us older Carrera owners may be considering moving to the 993 series. What are the weak points or problem areas to pay attention to or beware of? Cost considerations to address these issues would nice to know about also.
Thanks!
Old 01-31-2004, 11:13 PM
AFJuvat's Avatar
Here are a couple of common issues I've seen on 993. Not saying by any stretch that ALL of them have these problems, but these are the most common issues and maintenance "complaints"
1. Lower Valve Covers: they last anywhere from 25K - 30K miles, must remove mufflers to replace them,
2. Windshield "creak"
3. Rust on bottom corners of windshield frame. Porsche has 10 year rust through - Make Porsche fix it if you still have time.
4. AC Evaporator core: Yes, AC actually works well on 993, Unfortunately, the evaporator core tends to corrode and leak. This problem normally creaps up somewhere between 40K and 70K miles.
5. Steering rack: 993 has power steering, haven't seen a lot of these, go bad, but there have been more of then that what could reasonably considered to be "random failure"
6. Oil changes are "unique" The oil tank in the engine compartment is gone. the tank drain is in front of the pass side rear wheel., right above that (must remove wheel liner) is one of 2 oil filters. The other filter is where the engine mounted oil cooler used to be.
7. Twin plug dizzy: inspect on regular basis for snapped belt.
8. Spark Plugs: once the exhaust is off, it takes about 20 minutes to change 11 of the spark plugs. #12 (#6 cyl, upper bank) takes another 30 - 60 minutes to replace. The spark plug hole you see, is located under the power steering pump.
One huge advantage: No more valve adjustments
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-01-2004, 07:19 AM
Thanks, but I thought 993's have 1 sparkplug per cylinder.
Old 02-01-2004, 07:41 PM
scca_ita's Avatar
Alternator wire harness (The while engine harness basically) It is a factory recall. Make sure it was done.
Old 02-01-2004, 07:52 PM
MBruns for President
JeremyD's Avatar
CEL - Check engine light - valve guide wear or carbon build up... t2o plugs per cylinder. Check out how much the replacemend plug wire set is too - ouch!
Old 02-01-2004, 07:56 PM
Keep in mind the engine wiring harness issue is on the '95s and Porsche has been very good about upgrading it at no cost to the owner. Rear tire wear can be an issue but supposedly can be resolved by using later alignment specs.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-02-2004, 09:46 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Movin,
You visited this page?
http://www.p-car.com/
Pretty solid info. on 993 stuff there.
Kevin L
'86 Carrera "Larry"
Old 02-02-2004, 10:28 AM
Rick Lee's Avatar
My car chewed up the last set of rear Kuhmo Ecstas in about 7k miles. Found out my alignment was pretty off around that time too. I haven't had the leaky steering rack issue and my CEL hasn't come on either. I'm keeping my fingers crossed. I'm looking forward to DIY'ing a huge 45k miles service.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-02-2004, 10:43 AM
