Other than it won't meet Porsche specs what is the logic not to add a little STP to a 79SC transmission? A VW mechanic suggested it.
Old Tee all 911s sold |
Sometimes the STP will make the gear lube too slippery.
This will make the synchros work harder or not at all (makes the shifting harder). Bob
Bob Hutson |
I wouldn't risk it. As you know, synchros work on friction. Too much, they wear out, not enough, they just don't grab..and no synchronization....That is why one must be careful that they use the correct lubricant.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Same reason some synthetics won't work well...Porsche baulk-ring syncros especially need a bit of friction to work well. The later ( and more common) Borg-Warner cone style don't seem to suffer as much. More contact area ??
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thoughtfull responses, thank you. By the way, the VW mechanic is my brother-in-law. Just wait until the next family get together!
19 years and 17k posts...
OldTee,
I've been using Swepco 201 for the past year with great results. Have you tried it? I haven't used any additives and the shifting has improved noticeably...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I agree with Art, I use swepco 201 for my 79SC. Maybe try some of the swepco.
Old Tee,
What gear lube are you using in your 915 transaxle, and how recently was it changed. Porsche was recommending that the gear oil be changed at every engine oil change back in the '70s. What complaints do you have about your SC's 915? If your brother-in-law's suggestion was to use heavier gear oil, or along those lines, I suggest flushing the existing gear oil with Valvoline SAE 85W-140 gear oil. If that improves shifting quality, then change it again within 500 miles with the same, or change to Swepco 212.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Author of "101 Projects"
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=swepco
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
