Senior Member
Jdub's Avatar
Setting rear ride height: loaded or not?
Hey folks:
Thanks for giving me a hand yesterday on the 24mm thin wrench question.
The one thing that is not covered by the information I have is how to set the rear ride height: loaded, on the ground or on jacks, with wheels off?
I am about to lower the car after a full rear susp. rebuild and have set the springplates pretty much to middle point. Now, if I find that I have to lower the car further, can I do this with the car on the ground, or do I need to raise it on jacks and do my adjustments off the ground? Same for having to raise the car?
Many thanks,
John
'78 Targa in Minerva Blue
Old 02-02-2004, 06:23 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I did all my adjustments, be they front or rear, by jacking up the car. Then lowered it and bounced the suspension the best I could with all 170 lbs. of me.
Kevin L
'86 Carrera "Larry"
Old 02-02-2004, 07:16 AM
Jon Merck's Avatar
John do a search of past posts... I can't remember where I found it but their is a excellent step by step guide for home alignment/ride height on a 911. The author of the booklet is Ray Scruggs.
Good Luck
jon
Jon
Old 02-02-2004, 11:45 AM
