Help... drove the car (83 911sc) to work one night, it rained and I noticed water had gotten into the engine bay (wires) car would not start even after drying everything off. it's been 2 weeks since. anyone have a similar experience or know what the problem is?
If you are sure you are not getting a spark, then I would check that the CDI is making noise. If you are getting a spark, I would check that the fuel pump is running and that your air box is intact.
Graham Archer 83 911SC Cab |
Water might had shorted out the cdi box. If it whine (the cdi box) check for spark at the coil.
Re: No ignition spark!
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ditto on Ruf's advice
Mike 83 SC |
