Binge User
How much does it wiegh? Mine still works.
Paul |
Re: Redundant POS VDO clock died....
A boost gage! Why bother with anything less. This also means upgrading to a motor that has boost.
CHT gauge or tranny temp gauge...
2004 VW R32 - B road bahnstormer 1992 Peugeot 205 - Tarmac rally weapon (well eventually...) |
RETIRED
Hmmm, good suggestions....wonder if they make a combo CHT. volt meter and ERAM monitor.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Or a g-force meter
canna change law physics
How about a "blow tube" hooked up to the engine. It would be at least as effective as the E-RAM
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Plasma screen ?
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
I had been pondering this problem for some time , and a few months back I saw an article in that English magazine [cant remember the name] which featured a RS Replica with a Russian
Aircraft clock installed in that spot. Those clocks are magnificent-- 8-day wind up, standard fitting in all Soviet aeroplanes. They sell on E-bay and I intend to get one if they dont run out. Somebody might be able to scan the pic and post it. Bob |
Unregistered
If the boost gauge I just ordered fits in the hole I might be willin to part with my clock, it still wurks
Don't know about over there, but I replaced the mechanism inside mine with a brand new item for about $AUD80 (say $USD60). The same mechanism is used in most family (GM and Ford) cars here. Mind you I was quoted over $500 ($USD380) by my local Porsche Dealer for an original replacement item.
Sheldon '92 964 Carrera 2 (Manual) '07 BMW 335i '76 911 Carrera 3.0 (Gone, but not forgotten) "Give me ambiguity or give me something else!" |
Bob Goding,
Keep me posted on the clock. I might be interested, although I probably would make a clock for my den. Larry Harris
2001 Turbo |
My clock would only run when the engine was running. Made a great hour meter. Had it out several times trying to find out why it did this, everything had power, but it would only run with the engine running. Knew exactly to the min how many hours were put on engine each time it was started, set it at 12 then start, when I shut it down, all I had to do was look at the time and see how long I had it running. Got old after a while, I put a good used one in.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
How 'bout a Nav. unit
Wonder if you could take an old fuel / oil temp gauge, re-work it for cht/ alt. Might be worth a call to North Holywood Spedo.
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Heres a sample of the russian clock--they reckon about 3" dia.
This one is new but its a bit too pricy I think. Plenty of others tho. |
MBruns for President
Mike you may not be able to break this one...
These clocks have been designed to withstand speeds of Mach 3 / 1800 mph (2900 km/h) and altitudes of up to 100,000 feet (30 km). These robust timepieces are built to keep time flawlessly while pulling 6G’s!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
In all seriousness, for a street car? Especially one in which you don't care about originality? Voltmeter. Hands down the most useful gauge, and a gauge I feel Porsche should have put in as standard equipment.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Do you even have to ask???
Matt |
1980 911SC |
WTF? They came with a second hand??? My original clock died in the 70's. I replaced it with a newer Quartz clock of the same style. So far, nobody has commented on why it says "quartz" at the bottom of it's face...
My 81 sc doesnt have a second hand but has a hand u can set as a timer. Keeps perfect time. Also have a voltmeter which is very useful. It showed no alternator long before the light did.
Kevin '79 Coupe |
