-   -   Redundant POS VDO clock died.... (http://forums.pelicanparts.com/porsche-911-technical-forum/147079-redundant-pos-vdo-clock-died.html)
cegerer 02-05-2004 07:44 PM
Just a friendly warning Mike ..... rumor has it that this guy started out by replacing his clock one weekend ...... the "While I'm In There' syndrome took over ..... and well ..... the rest is history.
http://forums.pelicanparts.com/uploa...1076039037.jpg
MotoSook 02-05-2004 07:50 PM
Check out Westach Mike..lots of choices of dual or quad (!) gauges..size may be an issue, but I like cegerer's idea..LOL.
911ctS 02-06-2004 08:42 PM
Just set the time to 9:11 for good measures and leave it broken.
BTW- I tried hooking mine up to my battery charger on 6V setting and it charged overnight...gave it some kind of second wind and it has been working for a year now.
Joe Bob 02-06-2004 08:47 PM
They said they could do it....no problem for the volt/cht combo. They are looking into the insertion of the idjut light though...
al lkosmal 02-06-2004 09:56 PM
Set your dead clock to read 9:11. i did
hugo454 02-07-2004 04:45 AM
cylinder head temp. gauge
Wil Ferch 02-07-2004 09:34 AM
A combo volt and ammeter might have broader appeal than one that uses CHT...but I'd like either.
---Wil Ferch
Joe Bob 02-07-2004 09:36 AM
Ammeter.....what critical function would THAT monitor? What type of electrical component would start pulling a higher load that require a fulltime cockpit gauge?
tsuter 02-07-2004 09:40 AM
I'll trade my working 911 3" clock for a working VDO 3" Turbo Boost Gauge (vacuum w boost to 1.5bar).
Even up! :)
Wil Ferch 02-07-2004 09:52 AM
MikeZ:
Having both an ammeter and a voltmeter would give you some indication of the health of both the alternator and voltage regulator, common problem areas with our cars especially as they age.
....what?...too farfetched?
---Wil Ferch
Joe Bob 02-07-2004 10:07 AM
Not far fetched....just that how many amps something is pulling is something that I would use a multimeter for...AFTER I saw the voltmeter getting wierd....but hey, if i had room it would not be a bad thing.....
My ammeter question was based on "hmmmm", what would "I" really need a real time ammeter for....too many gauges would get me a rice complex....%^B
If I can't get the CHT/voltmeter....then a volt/ammeter would be my second choice. I'm just tring to get one that will allow me to put a check engine light it w/o cocking up my "other" gauges....
Wil Ferch 02-07-2004 10:16 AM
If you're of *that* frame of mind....
How 'bout CHT/EGT combo...they're used differently as diagnostic tools...
--Wil Ferch
Paul491 02-07-2004 10:30 AM
My vote is for the big red oil press light. I find it quite comforting on extended trips and spirited drives to know the "big idiot" behind the wheel will be promptly notified if oil press drops off. Cheap insurance. IMHO nothing is more critical than preventing a seized engine due to a slight momentary "oversight" during spirited driving, eh?
Just my .02 cents...
tsuter 02-07-2004 12:37 PM
Did someone say add on more gauges???
Ooops, wrong German car! :)
But I'll still swap my 911 clock for a boost gauge.
http://forums.newbeetle.org/attachme...&postid=372733
RarlyL8 02-07-2004 08:55 PM
Tsuter - here is your 1.5bar boost gauge.
I moved the fully functional and exactly correct all of the time sense its birth in 1978 clock down to the console. Where it still works just dandy.
http://forums.pelicanparts.com/uploa...1076216090.jpg
xlr8 02-07-2004 11:54 PM
http://forums.pelicanparts.com/uploa...1076226789.jpg
Padrino 02-18-2004 06:02 PM
Clock in my 70S works like a champ. Looses 10 minutes a week. But I think that has to do something about Einstein's theory about time and speed. I must be going too fast and the clock can't keep up!
xlr8 02-20-2004 11:43 PM
Tire pressure and temp monitor
http://forums.pelicanparts.com/uploa...1077349341.jpg
No affiliation.
}{arlequin 02-23-2004 08:36 AM
Where do some of you guys get that big oil pressure warning light? Is there any other way to add such a light, but smaller? I'd like to keep my clock, but also have an extra idiot light as well.
