Ign. timing specs for 2.7 RS? Help!
Trying to find the correct factory timing spec's for a 2.7 RS to use for a base point on an Electromotive HPX setup for same.
Thanks, Matt
'73 911 Targa / 2.7 RS spec |
Hilbilly Deluxe
They were posted a few days ago, the last time you asked this question:
Electromotive DIS timing curve for 2.7RS
Thanks emcon5 for pointing that out, but I am still trying to find the spec's for an RS and if you read the graph it clearly says EXCEPT Carrera. That means it is for T's, E's, S's but not RS's I think.
Thanks, Matt
Matt,
Evidently you didn't look very closely at the thread I posted several days ago ... the last chart at the bottom of the thread includes data from the '72 -'73 factory spec book, and shows the advance curve data in numeric chart form, both T,E,S engines and 2.7 Carrera! You can plot your own graph, if you choose ... distributor lube...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 02-05-2004 at 01:21 PM.. |
Oopsy! My bad! I have a 28.8 dialup connection and sometimes I don't wait long enough for pictures to load. Thanks again!
Matt
