having problem taking cat off
I have grinded off all the bolts holding the cat on and now I'm trying to sperate it from the heat exchangers. I can't get it to budge. Anyone have a suggestion?
Kerry
'91 C2T
'88 Targa - gone
http://www.pelicanparts.com/gallery/krichard/
Old 02-05-2004, 09:45 PM
v9ff's Avatar
You could try heating up that area where they connect... that should make them more receptive to a "prying" separation, no?
Old 02-05-2004, 10:16 PM
I don't have a Oxy/Mapp or acetylene setup just a propane torch and I don't think it will get it hot enough. I tried it for a while with no luck.
Kerry
'91 C2T
'88 Targa - gone
Old 02-05-2004, 10:20 PM
Autobahn Garage
Soak it with P.B.blaster, This stuff is the best thing I have ever seen.Autozone sells it as well as other stores. I'm shure this will help you good luck
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-05-2004, 10:30 PM
v9ff's Avatar
You say you've grinded off all the bolts... does that mean you just cut off the head and the end bolts? If the main part of the bolt is still in the hole then it might be the culprit. Perhaps you can try cutting the shaft of the bolts off inbetween the cat and heat exchanger.
Old 02-05-2004, 10:43 PM
Eric Coffey's Avatar
big rubber mallet?
Old 02-05-2004, 11:56 PM
cyprusx's Avatar
Take a punch and a hammer and punch those rusted bolts out.... I just did this and you have to get the bolts out before it will seperate...
Rick
88 Carrera Targa
-- There are only those that know and those that do not!!! --
Old 02-06-2004, 05:16 AM
